ac problem l
Old 10 Jul 2016, 08:28 am
Default ac problem l
i have a 03 turbo but this is a general question
i replaced one of the hoses low side the blue fitting the fat hose
ok i pump the ac for 1 hour it got it way down close to 30 ok
now i shut it off hoses removed everything let stand over night still showing the same pressure
ok 18 onces put in well it worked air cold 50 * it got cool great
now why would it leak down overnight dye over the same hose i just replaced
dye all aroundd where the hose was machined on you would think it it does not leak
my question if it held pressure over night doesn't that say there no leak it is a big leak to loose the freon that fast
Starter problem? Relay problem or others? postbeauty General PT Cruiser Discussions 3 22 Jun 2015 05:52 pm
2001 PT Auto Trans Problem and Engine Rev Problem johnwwjr Tech & Performance Forum 4 18 Apr 2015 10:00 am
AC problem became Overheating problem BilltheBrewer Tech & Performance Forum 1 23 Jul 2014 11:31 pm
Window problem and AC problem kaypriest Tech & Performance Forum 30 04 Jul 2014 07:42 am
is it a balljoint problem or a wheel bearing problem? phtech Tech & Performance Forum 2 05 Mar 2011 04:33 pm
