Disassemble Clutch Master Cylinder?
Old 10 Jul 2016, 03:28 pm
Default Disassemble Clutch Master Cylinder?
I know the Clutch Adjustment subject has been done to death - which is probably why I can't find the answer to my question. Too many threads...
Thanks to the info I found here, I just made it through replacing the clutch pedal bushing and adjusting the travel, but I'm thinking about a better aftermarket design. Whether my idea would work depends on one critical question:
Can I remove the actuator rod from the clutch master cylinder without destroying the MC?
All the new-part photos show the rod separated from the master cylinder but it looks like the rod end snaps into the piston and may or may not be removable after insertion.
If anyone has pulled a clutch master cylinder apart and can answer that question, I'd be most appreciative.
Doc
PS - Yes, I know about the Rage-Tek adjustment assembly. I want to do something entirely different.
Anyone changed the clutch master cylinder for a larger one? Trillion Tech & Performance Forum 0 17 Jun 2016 10:37 am
Clutch Master Cylinder discovering06 Tech & Performance Forum 4 10 Jul 2013 10:27 pm
Clutch Master Cylinder turbodog Classifieds: Want To Buy 0 04 Feb 2013 01:21 pm
01 Clutch oddity-possible clutch master cylinder? opelenvy Tech & Performance Forum 6 17 Sep 2008 03:35 pm
Clutch Master Cylinder iBorg Tech & Performance Forum 1 20 Feb 2008 01:02 pm
