Motor mounts ripped out... getting BE performance replacements
Like Tree4Likes
  • 2 Post By _PTGT03
  • 1 Post By _PTGT03
  • 1 Post By VsandFords
Old 11 Jul 2016, 04:01 am
_PTGT03's Avatar
Default Motor mounts ripped out... getting BP black path performance replacements
So Since February I tried filling the three out of the four stock engine mounts except the one right centre mount.
I did a good job, even profiled the rubber inside surfaces with a rough edge high speed die grinder bit.
the upper and lower right mounts, and the transmission mount i filled with shore 80a urethane.
after I filled the mounts i still was not satisfied with the performance. the wheels still were hopping.
last week after taking a speedbump at a higher than usual speed the last mount tore and broke.
now after doing a bunch of launches the upper mount failed and now the rest failed and now the damn thing is scraping along on the axle so that's keeping me out for a few weeks.
ordered these package;
, can get it off ebay.
BP 02-Up PT Cruiser Solid Upper Lower Motor Transmission Tranny Engine Mount Kit
.... and they come with a lifetime warranty, hell yes !
not sure if the top part is the right one but i'm assuming it's the right mid-engine mount. will update thread when it's installed. most likely going to replace the right axle as well.
here's a bonus image of my car taken at the right angle, and the right lighting
Old 11 Jul 2016, 08:57 am
Default Re: Motor mounts ripped out... getting BE performance replacements
Was there a reason the center mount was not filled other than the time it would take to remove/install it when you filled the other three? This is a good post for others that are thinking of filling the motor mounts.
How many miles do you have on the PT Cruiser?
Old 11 Jul 2016, 09:19 am
cruserdad1976's Avatar
solid mounts are supposed to be really rough im not sure exactally what that means other than I guess you can really feel the viberation
Old 11 Jul 2016, 11:49 am
_PTGT03's Avatar
these type of people should stick with their 70s cadillacs
that statement is true, but it's only exaggerated to a certain extent. performance oriented drivers prefer having faster throttle response, and faster launches without 'wheel hop'. i'm almost certain that the wheel hopping destroyed the existing mounts, over time and then they just spontaneously crapped out.
rockandroller likes this.
Old 11 Jul 2016, 11:52 am
you must remove the small locating pin
Don't do what I didn't do!
Had to take everything apart again because something wasn't right.
And then found this:
HOW-TO: AGP Dogbones Install - Dodge SRT Forum
Original join date: SEP 2003
Steve/ Wayne NJ
2005 GT Vert / Black / 5 speed
2004 Dream Cruiser / 5 speed Traded for 12 Veloster
2003 GT / Blue / Auto /sold
2001 Touring/ Silver / 5 speed /sold on E Bay
Old 11 Jul 2016, 12:04 pm
VsandFords's Avatar
Kit comes with a bottle opener? That's for the celebration when you finally get the job done. Or, for half way through when you REALLY need that drink! LOL
Because, you know, mounts not fun.
Old 13 Jul 2016, 10:57 pm
_PTGT03's Avatar
No time, and I had never tried it before, lack of experience.
156,000 KM
Old 16 Jul 2016, 02:40 pm
_PTGT03's Avatar
whoops, screwed up on my ebay address so will have to wait a bit to get that sorted out . i will have to get my car towed back home so i can work on that, and will have to get that arranged sometime today or tomorrow.
Motor Mounts pressman57 General PT Cruiser Discussions 2 03 Apr 2015 03:11 pm
Motor Mounts rckstein General PT Cruiser Discussions 6 13 Jul 2014 06:14 pm
Motor mounts - How many and where? rbf7 General PT Cruiser Discussions 10 14 Sep 2012 10:42 am
performance motor and tramision mounts and "torque struts" srebik Tech & Performance Forum 3 31 Jul 2010 01:51 am
PT MOTOR MOUNTS HELP !! BARRYPT General PT Cruiser Discussions 2 18 Jan 2008 12:44 am
