Clutch
  • 1 Post By chuzz
Old 13 Jul 2016, 05:38 am
Default Clutch
01 - Driving, pushed in clutch and came to a stop, clutch did not fully disengage with pedal pushed all the way in. Took off and was difficult to engage gears, stopped again, same problem, stopped again, hard to engage 1st but clutch was disengaged. Clutch reservoir is full.
Old 13 Jul 2016, 06:44 am
Default Re: Clutch
Did you check the slave cylinder? Just because the master if full, doesn't mean the slave is okay. If both are full, then maybe it's time to check the fluid level in the transmission. Have you ever done that? How many miles on the car?
917K likes this.
Old 13 Jul 2016, 07:09 am
Default Re: Clutch
Yes, both are full. I have not checked transmission, though did not really think about trans oil making clutch not disengage. Has 109,000 on it.
Old 13 Jul 2016, 01:14 pm
rob302's Avatar
Default Re: Clutch
adjust the rod at the master under the dash. it may buy you about a years time.
Stiff transmission when hot?
free and fairly easy to try.
Which clutch set JMWEBB General Turbo Discussions 1 10 Jan 2014 02:24 pm
clutch stockss Tech & Performance Forum 5 25 Feb 2011 12:50 pm
wtb clutch Dirk_Gently Classifieds: Want To Buy 1 10 Dec 2008 09:57 am
01 Clutch oddity-possible clutch master cylinder? opelenvy Tech & Performance Forum 6 17 Sep 2008 03:35 pm
GT 5 speed clutch noise or " clutch chatter". boosta General Turbo Discussions 3 11 Aug 2003 08:10 pm
