pt suddenly stops
Like Tree4Likes
Old 18 Jul 2016, 12:23 pm
Default pt suddenly stops
hello, i have a 2001 pt cruiser which has devolped a really scarey random fault.
at any speed it will just cut out,no warning just dies.i manage to coast to a halt.have to remove the key reset the car then she will start.she might go for another day or a minute.no warning no nothing.not a good driving exp.have changed crank sensor but no change.any help most welcome.i love the car but its to dangerous to drive as is.
car is a euro model 2.0il with 100.000 on the clock
Old 18 Jul 2016, 12:33 pm
Default Re: pt suddenly stops
Welcome to the forum
Old 18 Jul 2016, 12:42 pm
Welcome to the forum.
When this happens is there anything else that stops working?
Have you checked to make sure all battery cables connections are good?
Does your engine light come on when this happens? If so what are the engine trouble codes?
You might want to check and see if the ignition actuator is working properly or if there is a problem with the ignition actuator pin if everything else checks out good.
Old 18 Jul 2016, 12:44 pm
VsandFords's Avatar
Old 18 Jul 2016, 03:28 pm
rckstein's Avatar
Old 18 Jul 2016, 03:40 pm
Teekypt's Avatar
Send a message via Skype™ to Teekypt
Welcome to the forum!
You might also have a faulty/overheating PCM/ECM.
I replaced mine a couple of years ago and it did the same thing. Was driving with no problem and then just quit while I was stopped at a light. I had no indication of any issue beforehand. Then I had it towed to my mechanic and he told me that he was able to crank it and then it died a while after.
He ran a diagnostic and said that when the PCM was cool in temperature, it would temporarily work and allow my car to crank/run. As soon as it started to overheat, it would stop working, resulting in my car shutting off with no warnings of any kind.
So, you might want to check it out as well.
2003, GT, "ShuggaPlum", xenon bumper kit, custom grey/black CoverKing seat covers (front & back).
Sunrise: July 2002
Sunset: June 2018
http://www.math.uh.edu/~tai/Today/Clean3.jpg
Old 18 Jul 2016, 05:11 pm
Make sure you check everything else before thinking of replacing the PCM. Some members have had the Crankshaft or Camshaft wiring found to be shorting to ground on the half shaft or on the engine block, etc. after finding out it was not the PCM. Check the wire harness between the crankshaft and the PCM. Same with the Camshaft sensor.
Teekypt likes this.
Old 18 Jul 2016, 08:23 pm
Teekypt's Avatar
Hey! Great advice! But my issue really was the pcm. As soon as it was replaced MY issue went away.
Sunrise: July 2002
Sunset: June 2018
Old 18 Jul 2016, 08:59 pm
Handy_Cruiser's Avatar
First, welcome to the forum from the great sovereign state of Arkansas!
Are you getting any trouble codes? And if so, what are they? A crank or cam sensor would likely be throwing codes.
Old 18 Jul 2016, 09:53 pm
That question was already asked in post #3.
I have attached post #3 below.
Suddenly strange error codes Fifty4F100 Tech & Performance Forum 5 21 Apr 2015 08:29 pm
Suddenly won't start jdege General PT Cruiser Discussions 7 06 Jan 2012 06:50 pm
PT Suddenly Runs Rough Poncho Villa Tech & Performance Forum 7 18 Dec 2010 05:03 pm
2008 PT Cruiser suddenly won't start DogsPT Tech & Performance Forum 3 14 May 2010 07:04 pm
Suddenly - no fresh air Red Octopus General PT Cruiser Discussions 5 21 Mar 2007 09:37 pm
