Radiator Fan Issues Part 2
Like Tree19Likes
Old 20 Jul 2016, 06:05 pm
Default Radiator Fan Issues Part 2
So I posted earlier that I just got a used 06 pt and the fan relays had been relocated. I think the mounting bracket had broke so he pulled the relays to the other side of the radiator and wire tied them in place. I had a bad relay, replaced and all is good.
Except that the relay has gone again, or maybe it was the other one. To be safe I had replaced them both. So I took them both back to AZ and they exchanged them. I placed them back in and when I run the car I can hear a faint clicking coming from one of the relays. After a bit it seems to get hot.
So I swapped the relays and the clicking continued from the same socket. So I do not think it is the relay. But I do not know what it is from. Any ideas on what could be causing this? I am assuming that is what is causing the relays to burn out.
2006. 2.4 Vin Code "B".
Old 20 Jul 2016, 06:34 pm
rckstein's Avatar
Default Re: Radiator Fan Issues Part 2
It may be the short section of wiring harness to the relays. Check the connector on the other end where it connects with the main harness, see if that connector isn't partially melted. On my PT, that connector was melted, the last time they replaced the fan. You can get a new section of harness, but only with a new fan. If you need a new section, you may be able find one at a you-pull-it yard. In any case, you should try to fix the issue and get the relays back to their original location.
Old 20 Jul 2016, 06:58 pm
LionPT's Avatar
It could be that the low or high speed brushes are bad...meaning that the 2 speed fan only has 1 working speed.
Old 20 Jul 2016, 08:00 pm
There is a good possibility the radiator fan relay is clicking caused by low voltage. Chances are you have a short in the radiator fan circuit pulling the voltage down. One of the wiring in the radiator fan motor might have high resistance causing the voltage to pull down. If I was in your shoes I would just replace the radiator fan. I have a brand new one in the garage in case I have any doubts in either one of my Pt Cruisers. I prefer a peace of mind knowing that with a new radiator fan I have a good chance of keeping the engine cool.
Teekypt and rckstein like this.
Old 20 Jul 2016, 08:35 pm
rckstein's Avatar
If you do replace the fan assy, you should get the one that includes the relays and wiring harness, it's not that much more from the bare fan, and your wiring harness has already been hacked up, so the replacement would fix that issue, too.
Teekypt likes this.
Old 21 Jul 2016, 09:22 am
Thanks for all the replies.
I could not find a replacement radiator with the wire harness locally.
I did get a new fan from AZ.
I removed the wire harness and examined it, there is no signs of wear.
The new fan is still clicking the relays.
What else could it be?
Old 21 Jul 2016, 10:15 am
Is the clicking coming from the low speed or high speed relay?
Where did you get the new radiator fan?
Old 21 Jul 2016, 11:20 am
Steve, he got the fan from Autozone. Hmmmmmm.
Old 21 Jul 2016, 12:11 pm
rckstein's Avatar
NAPA has the fan complete with harness and relays.
Old 21 Jul 2016, 01:31 pm
I would test both hi and low fans using jumper wires from the battery with an inline amp meter to see what the fans are drawing. It sure sounds like something is wrong with the fans causing a high amp draw.
Radiator Cap - new style/part number panjammer General PT Cruiser Discussions 7 22 Nov 2012 09:21 pm
Radiator Issues Bretalexa Tech & Performance Forum 7 24 Apr 2012 03:04 pm
Parts store has wrong part # for radiator fan? CashReject Tech & Performance Forum 1 12 Mar 2012 11:31 pm
Radiator/cooling fan relay part number for PT 06? TwoCats Tech & Performance Forum 23 24 Jan 2012 10:35 am
Radiator Issues misfitmommy General Turbo Discussions 2 02 Nov 2010 07:16 pm
