Horn silent after following various "fixes"
Like Tree2Likes
  • 2 Post By CREWZIN
Old 20 Jul 2016, 07:53 pm
Default Horn silent after following various "fixes"
I have just taken possession of a 2003 Limited edition Cruiser with 141000 KM on it. Runs OK but few electrical problems. Cruise stopped working although icon shows on dash, fog lights wont turn off ( fuse pulled) and Horn doesn't speak. I pulled horn and it works on bench, the fuse is OK, I can hear the relay activate when I push the steering wheel pad, I took the ground off the battery and did a continuity check between the cable and ground (green wire ?) on horn plug,. no continuity. I wired a grounding wire between steering column and bracket as suggested by another thread, didn't work. I'm not sure how system works , relays, switches etc...so have no clue what to do next. Any suggestions.
Old 20 Jul 2016, 08:00 pm
VsandFords's Avatar
Default Re: Horn silent after following various "fixes"
Welcome to the forum.
Old 20 Jul 2016, 08:33 pm
i would suggest checking the clock spring if your airbag light is also on.
Old 20 Jul 2016, 08:34 pm
This is from the Haynes manual, maybe it will help.
Old 20 Jul 2016, 09:02 pm
rckstein's Avatar
Old 21 Jul 2016, 08:27 am
Yep , the light is on. I,ll do some more reading and move on don't know if I'll tackle this job. thanks for the reply.
Old 21 Jul 2016, 11:23 am
It's not that difficult of a job. The one thing you want to remember is to disconnect the battery and give it a few minutes before beginning the job. That way, the air bag capacitor has time to discharge and won't blow out on you.
Old 21 Jul 2016, 11:28 am
Old 22 Jul 2016, 09:59 am
Thanks for the help, going to pick up part and get at it in the nextweek or so. Thanks again.
Tags
2003 pt cruiser, cruise control, horn
How can I disable the horn/toot when i push "lock" kurty General PT Cruiser Discussions 25 15 Aug 2016 08:54 pm
The "Handy" NOPI Strut Bar Install: Part "Deux" (2) Handy_Cruiser Tech & Performance Forum 2 01 Aug 2015 10:37 pm
Turbo "phhsssss" or "whoosh" sound--Normal? Silenceable? Help! Memark General Turbo Discussions 13 24 Nov 2010 10:56 pm
Having a louder "Horn" wayneman PT Cruiser Convertible Forum 9 06 Jul 2010 09:28 am
