About to start timing belt job!
Like Tree3Likes
  • 1 Post By Handy_Cruiser
  • 1 Post By fisheyestudio
  • 1 Post By rckstein
Old 21 Jul 2016, 05:49 pm
Default About to start timing belt job!
Hey Howdy hey!
The cruiser is in the shop and up on jack stands. I am watching this video series on the timing belt job https://youtu.be/6qRrgHvZRMQ and have read several threads on this forum.
Has anyone done this job without removing the AC lines? The mechanic in the video seems to imply that it is possible but makes the job a bigger pain.
Thanks in Advance.
Old 21 Jul 2016, 06:15 pm
Default Re: About to start timing belt job!
Here's an older thread to read....
Can Timing Belt Be Changed Without Opening A/C System?
Old 21 Jul 2016, 09:11 pm
Handy_Cruiser's Avatar
Originally Posted by fisheyestudio View Post
Hey Howdy hey!
Thanks in Advance.
Yep. No need to discharge the AC or disconnect the exhaust. Just rock the engine gently back and forth as you raise it up to make sure nothing gets hung. I was fitting some new camshafts and valve train mod when I did mine, so I had it off three times. Nothing to it. Quite a bid easier than on my former Sebring convertible. Here's a photo of my engine jacked all the way up.
And there's plenty of room with AC line still in place.
thecabinguy likes this.
Old 22 Jul 2016, 12:44 pm
Thanks for the pics. I have it all apart now and did not have much trouble working around those lines. Sure glad I didn't take them loose. I was concerned over the range of movement for the engine when jacking it up and lowering it. A couple of the bolts were impossible to get out without significant engine movement.
I am waiting on a three arm gear puller so I can remove the balancer. Then I can find TDC and remove the belt.
Thanks again!
Handy_Cruiser likes this.
Old 22 Jul 2016, 12:46 pm
Old 22 Jul 2016, 01:13 pm
rckstein's Avatar
While you've got the area torn apart, you might want to replace the center motor mount, they are known to tear, the same as the torque struts, but much easier to replace now, rather than later.
chuzz likes this.
Will not start after timing belt change. britt Tech & Performance Forum 14 29 Oct 2013 12:44 pm
Timing Belt Changed and now will not start - HELP rhowle Tech & Performance Forum 3 18 Mar 2012 08:59 pm
After timing belt wont start moparman75 Tech & Performance Forum 1 17 Apr 2011 10:39 am
timing belt/ no start/ no compression sylster General Turbo Discussions 8 01 Mar 2010 08:42 pm
timing belt no start YouPutz Tech & Performance Forum 17 27 Feb 2010 04:38 am
