2005 pt cruiser
Old 25 Jul 2016, 05:46 pm
Default 2005 pt cruiser
I just replaced my crankshaft position sensor and my camshaft position sensor.
When I first drove off after replacing them. The car ran great. 10 min later it was missing up again. It bogs down when I excellerate. Just like the codes said. I changed the sensors. Is there a chance there's a wiring problem. The car runs great when its cold. When it warms up it start doing same thing it did before. Is there a chance there could be a bear wire or something that's causing this. Anyone had anything like this????? Let me know.
Old 25 Jul 2016, 06:09 pm
Default Re: 2005 pt cruiser
See if the wiring to the crankshaft sensor is rubbing on the half axel.
2016 Kia Soul Plus Black
Old 25 Jul 2016, 07:06 pm
I will do that. thanks. I don't know what else it could be. It has to be a wire somewhere.. That's as good a place to start as any. Maybe I will get lucky and that will do the trick
Old 26 Jul 2016, 08:07 am
MJKnight's Avatar
I had to replace both sensors ....
didn't fix it until I replaced
the camshaft magnet,,,,
Old 26 Jul 2016, 08:15 am
Fk5 Fk5 is offline
Never had this problem with a PT, but...
Does the problem actually come and go with the engine getting up to temp? A friend had a Jetta and those were notorious for having bad temp sensors. The car would run great cold, but when it got to closed loop, the temp sensor was all over the map and it was hit and miss.
Open loop is generally rich, it also might be something making the car prefer to run rich. The ultra-gauge and most of the scanners should tell you if the car is in closed or open loop. I would keep an eye to see if that is where the car falls on its face.
Of course, first you should check your wiring. That is always a good idea.
2003 GT 5 speed
162,000 miles
Old 26 Jul 2016, 08:31 am
What are all the engine trouble codes?
Have you reset the codes with an OBDII Scan Tool and got the same codes to come back?
How many miles do you have on it?
Has the wiring harness been repaired previously from the crankcase, camshaft to the PCM?
2005 PT CRUISER effecinco Southeast PT Forum 3 05 Jun 2016 10:02 am
Refurbished 2005 PT CRuiser Dream Cruiser Series 4 Convertible soonercruiser craigslist 4 13 Mar 2015 04:10 pm
2005 pt cruiser tbone6675 Tech & Performance Forum 6 12 Sep 2014 08:11 pm
2005 Cruiser sancapwork Tech & Performance Forum 10 21 Jul 2014 12:48 pm
2005 PT Cruiser TCM adstatus Tech & Performance Forum 2 16 Aug 2013 12:06 pm
