Sea foam epidemic
Like Tree7Likes
Old 25 Jul 2016, 08:49 pm
Default Sea foam epidemic
Hey all,
I put in Seafoam into my gas tank today to get some cleaning done along the fuel system - and right as it started to flow through I noticed that my car had a nasty rough idle to the point where the car dies sometimes. Also I heard scraping in the engine bay which I know for sure isn't a good thing. The car has 130k on it, and so I'm assuming due to the high mileage and the lack of care along the fuel system I'm sure that is what is causing it. So, my game plan is to wait a little bit until my spark plug wires get in and then change my plugs, wires, coil pack, and then clean out my throttle body and run the tank low on gas (about 1/4) and fill it to dilute the Seafoam.
If anyone has any other suggestions in more than open to them. Thank you.
Old 25 Jul 2016, 09:19 pm
Exclamation Re: Sea foam epidemic
Real quick update: I looked under my car and realized that there is a nasty leak under the car and the fluid was red which is indicative of transmission leakage... Will investigate more tomorrow.
Old 25 Jul 2016, 09:32 pm
Default Re: Sea foam epidemic
As far as the coil pack, I've read it is extremely rare that they go bad in PT Cruisers.
2016 Kia Soul Plus Black
Old 25 Jul 2016, 10:39 pm
LionPT's Avatar
Try Berryman B-12, I don't think that there's anything better.
Berryman B-12 Chemtool Carburetor/Fuel Treatment and Injector Cleaner
You can pretty much pick it up anywhere...even Walmart.
Just pour the whole bottle into 1/2 a tank.
Old 26 Jul 2016, 08:21 am
Xylene
Old 26 Jul 2016, 08:25 am
While sea foam is not the best bang for the buck. I don't think it's your problem. I have not heard of any one having created a problem on a car useing a gas treatment. Plugs could be suspect. And can just act up all of a sudden. Pulled out a set in a truck that seemed to run fine till one day it just would hardly run. Pulled them out and huge gap. Why no symptoms prior I will never know.
cruserdad1976 likes this.
Old 26 Jul 2016, 08:36 am
rob302's Avatar
That stuff is fun. Address the trans leak and then just go beat the piss out of the car and sea what happens
i've never been scared by seafoam before.
Old 26 Jul 2016, 11:14 am
cruserdad1976's Avatar
I guess im either relaly lucky or just ODD
I change my oil every month and add a bottle of lucas oil stabilizer 3 quarts of Castrol Edge and a wix filter ever month
I also add a full can of sea foam to my tank it does make a oil change really expensive but I drive a lot of miles and I don't want to work on my car every night so I do what I THINKS WORKS FOR ME
and then just because I can like every other month I will add a quart of Marvel Mystery Oil in place of a quart of oil
I don't think I ever put sea foam in the oil I don't think I knew you could I guess it helps keep the engine clean??
anyway I have never had any issues with sea foam
I don't know if 1 botrtle a month helps anything but I don't think it can hur anything either
Old 26 Jul 2016, 03:22 pm
Your last line is as true with all gas aditives.
Old 26 Jul 2016, 04:00 pm
I don't really know if any of that helps a motor last longer but it easies my mind that I did all I could and I do usally get close to or a little over that 200,000 mark but then that could just be from doing regular oil changes
Fuel filler foam up! rstevenson General PT Cruiser Discussions 27 18 Jun 2015 06:10 pm
littoe FOAM filter in airbox? bryman Tech & Performance Forum 22 23 Mar 2012 07:11 pm
Added Memory Foam to Seats Retroguy General PT Cruiser Discussions 5 07 Apr 2011 07:08 am
Sea Foam method dsmturbo General Turbo Discussions 1 27 Apr 2010 10:09 am
*need foam insert to bumper milPT Classifieds: For Sale/Trade 0 20 May 2004 05:07 pm
