2005 2.4l no crank, no start. Need help!!!!!
Like Tree2Likes
  • 2 Post By wayne272
Old 26 Jul 2016, 07:41 pm
Default 2005 2.4l no crank, no start. Need help!!!!!
wife took car to carwash, after attendant cleaned windows, etc. she got in to leave, turned key and nothing. They tried jumpstarting and got nothing. Also the reverse lights stay on with key in run position no matter which gear its in (automatic).
Things I checked:
1. battery has good voltage and had load tested
2.all fuses in pdc good(asd,ign start,ign run,pwr)
3.swapped horn relay with starter relay, asd relay
4. fuel pump comes on
5. dash lights, radio windows all work
6. red light goes out after a few seconds
7. 0 volts at solenoid start wire with key in start position
8. jump pins 30-87 in starter relay cavity engine cranks
9. jump solenoid with screwdriver engine cranks
10. pins 30,85,86 on starter relay all have 12 volts with key to start
11. 0 volts pin 87 with key to start
12. grounded pin 86 on starter relay with key to start engine cranks
Need some ideas of what else to check. Don't know if the reverse lights problem could be related, they were fine before. All ideas would be greatly appreciated.
Old 26 Jul 2016, 07:46 pm
Fk5 Fk5 is offline
Default Re: 2005 2.4l no crank, no start. Need help!!!!!
The reverse lights problem is new? If that is the case, I would guess it is the neutral safety switch (or whatever you call it on the automatic) that is keeping it from starting. If the car thinks that it is reverse it shouldn't crank. I would follow the wiring chart and try to figure out where it went wrong.
2003 GT 5 speed
162,000 miles
Old 26 Jul 2016, 07:51 pm
LionPT's Avatar
Also, pull the center console & check that the cable is still attached to the shifter.
Old 26 Jul 2016, 08:02 pm
The cable would have to be attached since i was able to shift into neutral to tow it home. Is there a switch for the reverse lights? Wher would the neutral safety switch be located? I have a Haynes manual and i can't find the switch in there and their wiring diagrams stink.
Old 26 Jul 2016, 08:15 pm
Will pull console and check, will also try disconnecting cable at transaxle and moving shift arm see if i have any luck.
Old 26 Jul 2016, 09:42 pm
Fk5 Fk5 is offline
I know close to nothing about the automatics, but I was able to download the 2003 Chrysler manual online. You can probably find a link someplace. Maybe even here. Sorry that I don't have one now, but this isn't the computer I saved it on.
2003 GT 5 speed
162,000 miles
Old 15 Aug 2016, 03:50 pm
It turned out to be the transmission range sensor that had a broken pin on the part inside the transaxle. looking at the wiring diagram, it is the switch for the backup lights. thanks for all the help.
Old 15 Aug 2016, 04:06 pm
Thanks for telling us what the problem was.
How many miles on the transmission?
Old 16 Aug 2016, 12:01 pm
120k miles on the odometer
crank no start conrad PT Cruiser Videos 8 20 Sep 2016 02:34 pm
crank but no start when it's hot outside Farrar Tech & Performance Forum 12 19 Sep 2016 07:49 am
2005 cruiser won't crank to start OJR Tech & Performance Forum 17 12 Dec 2015 04:28 pm
CRANK BUT NO START clifford General PT Cruiser Discussions 3 27 May 2014 11:15 pm
2005 NO crank yantigani Feedback and Support 1 03 Oct 2013 01:08 pm
