Need help with bolt size on engine bracket.
Old 27 Jul 2016, 07:59 am
Default Need help with bolt size on engine bracket.
Well i recently blew my timing belt and as i was taking it apart somehow i managed to bend one of the three bolts that hold the engine bracket to the engine. Does anyone know off hand what the type and size bolts these are. And does anyone know where to get them as the dealer says they do not carry those and that the engine bracket is not a serviceable part. Interesting! Anyway thanks for any help.
Old 27 Jul 2016, 08:11 am
rob302's Avatar
Default Re: Need help with bolt size on engine bracket.
This help?
Need help with crossthread engine mount bolt
You might call another dealer for that t55 bolt.
Old 27 Jul 2016, 08:15 am
rob302's Avatar
More threads on this
https://www.google.com/search?&q=sit...ount+bolt+1.75
Old 27 Jul 2016, 08:25 am
Thank you for this but it's not the motor mount t-55 bolt that i need it is the three bolts that hold the engine mounting bracket to the engine block. #1 in the image
Old 27 Jul 2016, 06:19 pm
_PTGT03's Avatar
any competent engine rebuilding shop you should call and ask for advice. they should have a list of bolts for that engine or possibly even know how to repair it or replace these.
Old 27 Jul 2016, 08:13 pm
RickinPA's Avatar
Some years ago I purchased a slightly longer bolt for the lower strut bracket on my PT. I wasn't satisfied with the length that engaged the bracket on the motor. I had to tap the bracket a bit to get the longer bolt to engage but it worked well. I bought the bolt from McMaster-Carr as I remember I had to buy a pack of 5 but the cost wasn't too bad.
It should be a metric bolt. You should be able to measure it and figure out the size. Watch the marking on the head as that indicates bolt strength, buy a matching strength bolt.
Old 28 Jul 2016, 10:26 am
Thank you all for your help! After doing my homework i have come to the conclusion that the bolt size is M10x1.25x100 class 10.9 full thread with a 3mm 10mm i.d. 20mm o.d. washer so i will leave this here in case anyone ever needs this info!
PT Cruiser engine mounting bracket bolts - Album on Imgur
Exhaust Manifold Support Bracket Bolt bennyc General PT Cruiser Discussions 9 15 Jun 2016 07:32 pm
removing the accursed engine support bracket & broken bolt on engine mount ushumgal General PT Cruiser Discussions 6 11 Dec 2015 04:47 am
Caliper mounting bracket bolt size Ptcruisershort General PT Cruiser Discussions 2 18 Apr 2012 12:08 am
WTB - 06506379AA - Engine mount bolt (frame though bolt) wheelgarage Classifieds: Want To Buy 5 04 Dec 2011 10:31 pm
What size is this bolt??? hidinginparadise General Turbo Discussions 3 06 Mar 2011 07:59 pm
