P0551 Code My car does not have sensor
Like Tree2Likes
  • 2 Post By ptcruisersteve
Old 31 Jul 2016, 12:34 am
Default P0551 Code My car does not have sensor
Hello all. I need some help. I have a 2005 PT with about 68,000 miles and the check engine light has been on for a few months. I need to take care of it now because I need to get a smog check. I had a friend check it out to replace the sensor and I do not have one. We checked for leaks and there are none. What should I look for now? Any advice will help.
Thanks
Old 31 Jul 2016, 01:01 am
Default Re: P0551 Code My car does not have sensor
P0551 - Power Steering Pressure Switch Circuit Failure:
Possible Causes:
1. Power Steering Pressure Switch sense circuit is open or is shorted to ground
2. Power Steering Pressure Switch ground circuit is open
3. Power Steering Pressure Switch is damaged or it has failed
4. PCM has failed
Has the power steering unit been replaced with one from a junk yard?
Old 31 Jul 2016, 01:17 am
It has not been replaced at all. The only thing I have had to replace on the car is the clutch and camshaft position sensor. I am not sure what else to look for I was ready to replace it. Do you think dirty power steering fluid can cause it? I have been researching and most people just replace it and fixed.
Old 31 Jul 2016, 01:48 am
Does your friend know where the power steering pressure switch is located?
It should be mounted on the rear of the rack on the driver's side.
Did you check to make sure the power steering fluid level is okay?
Old 31 Jul 2016, 02:02 am
That is a great question. I thought they did but I might have to take a look myself. I will do some research and watch some youtube videos and tackle it tomorrow. I know it should be a simple fix. I hope it is.
Thanks for the picture.
Old 31 Jul 2016, 02:22 am
Did your friend go under the PT Cruiser to see it?
Error Code P0551 ????????? Baranca General PT Cruiser Discussions 2 12 Oct 2014 09:16 am
error code p0551 Ellenlyle General PT Cruiser Discussions 4 24 Jan 2014 02:32 pm
Code P0551 twodees Tech & Performance Forum 3 11 Mar 2013 10:50 am
Code p0551 LNBNDN Tech & Performance Forum 4 26 Oct 2011 08:51 am
Code P0551 - How Serious? BB General PT Cruiser Discussions 8 17 Aug 2005 11:12 pm
