GETTIN HOT 04 PT..??
Like Tree2Likes
  • 2 Post By Handy_Cruiser
Old 05 Aug 2016, 05:50 pm
Default GETTIN HOT 04 PT..??
04 NON TURBO..AUTO,,
NEW THERMOSTAT
NEW FAN..WORKS IN BOTH SPEEDS AS SHOULD
NEW WATER PUMP/TIMING BELT..
ON HOT DAYS HIGH 80S AND UP..STARTS GETTING HOT DRIVING ,,
CREEPS UP TO ABOUT A NEEDLE ABOVE THE 3/4 MARK,,FIRST MARK PAST CENTER..
I CAN TURN ON THE HEATER AND IT WILL COME BACK DOWN FAIRLY QUICK..??
FANS WORKING GOOD..COOLENT GOOD..
MY QUESTION IS COULD THE RADIATOR BE SOMEWHAT STOPPED UP? CAUSING THIS? IT DOSENT GET HOT ON COOL DAYS..AND ON HOT DAYS ON A LONG UPHILL PULL IT WILL GET HOT TOO..
COULD IT HAVE AIR IN THE SYSTEM? ABOUT READY TO BUY A NEW RADIATOR?
Old 05 Aug 2016, 06:48 pm
Handy_Cruiser's Avatar
Default Re: GETTIN HOT 04 PT..??
First question - Did you use the bleed valve below the thermostat to get the air out of the system? It's very hard to get her "burped" without using that valve.
Old 05 Aug 2016, 08:13 pm
Does it overheat at high speeds? If it does not overheat at high speeds chances are your radiator is fine.
Old 07 Aug 2016, 12:06 am
No haven't burned it there? Do I get it up to temp then open that bleeder
Yes still. Gets hot at 60mph never more that a needle above 3/4..
Old 07 Aug 2016, 12:38 am
DroptopPTGTCruizer's Avatar
You want to do all coolant adjustments while car is cool. The link below is from this forum, I recently provided a detailed explanation on purging the air out of your PT coolant system using the bleeder valve. The process described worked perfectly for me, other members may have alternate suggestions but only a couple ways to really yield the same result. Good luck getting your issue sorted out.
No coolant/overheating; how to fix?
2005 PT GT Convertible HO Turbo Autostick ~ black/black leather ~ 53,000 miles ~ summer-only driver ~ OEM rear sway bar ~ K&N 57 series CAI ~ 4-wheel ABS ~ Hawk Sector 27 drilled/slotted rotors ~ Hawk Performance Ceramic pads ~ Firestone Firehawk Indy 500 Wide-Oval performance tires ~
Old 07 Aug 2016, 01:20 am
Have you checked your radiator cap?
I would suggest a coolant pressure check to make sure your coolant system is sealed if you are losing coolant.
Not new. Just gettin back to the site. GrapeApe Welcome New PT Cruiser Members 9 09 Mar 2015 01:40 am
Gettin' Ready for RTTB! soonercruiser Southeast PT Forum 2 09 Oct 2014 11:48 pm
Gettin' a new car!! Sissy General PT Cruiser Discussions 12 17 Apr 2003 08:18 pm
