Clock spring replacement
Old 06 Aug 2016, 07:04 pm
Default Clock spring replacement
I have numerous electrical problems with my 2003 PT Cruiser, from a previous post PTCruiserSteve suggested the clock spring could be the problem, and I think there may be a problem with the multifunction switch. I have picked up a steering column complete, with the exception of air bag. I was with the mechanic when he removed the steering column and care was taken not to rotate the wheel and it was wired to keep it from rotating. I was going to replace the whole column but switch out the starter cylinder and use the one that is in the car now, there is also a remote starter wired to the cylinder body in the car now. My question, will things still work if I swap cylinders in the replacement stering column?
Old 06 Aug 2016, 09:31 pm
Handy_Cruiser's Avatar
Default Re: Clock spring replacement
I've done this swap before.
The only things you have to swap out are the SKIM module and the key cylinder.
I don't know about the remotes starter wire. But I imagine that if you hook it up as before, everything should work as before.
Here the SKIM module from when I swapped out my column:
Clock Spring in a 2003 PT Cruiser SHELMAC General PT Cruiser Discussions 4 17 Jun 2013 05:33 pm
Clock Spring compatability schwasskin General PT Cruiser Discussions 2 22 May 2013 09:00 pm
i need a clock spring for my wifes 04 pt can anyone help me ?? bobs turbo pt Classifieds: Want To Buy 5 15 Jan 2009 02:26 pm
o4 clock spring needed can anyone help me ?? bobs turbo pt General PT Cruiser Discussions 1 07 Jan 2009 04:53 pm
Need airbag clock spring source Poppapug General PT Cruiser Discussions 3 15 Sep 2008 08:26 pm
