PT won't crank....tried everything!!!
Like Tree2Likes
Old 06 Aug 2016, 10:38 pm
Default PT won't crank....tried everything!!!
I have a 2003 Touring and I can't get it to even try to crank. When you turn the key, you can hear the fuel pump fire up and then...nothing. You can jump the starter and it will fire up. I tried changing the starter anyway, but no luck. I checked the ignition switch and cylinder and both are ok. I checked the fuse and relay and they are also ok. I'm running out of parts to check! Also, the battery has gone dead and I have to do all of my checks jumped from another car. Anybody have any ideas? I'm stumped! Thanks!
Old 07 Aug 2016, 01:00 am
Default Re: PT won't crank....tried everything!!!
Welcome to the forum.
Have you checked the starter relay?
When you turn the key to start the engine are you getting voltage to the solenoid?
Old 07 Aug 2016, 04:33 am
As you found out if you can jump the starter and the car starts the starter is good.
How did you check the ignition switch?
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 07 Aug 2016, 06:36 am
Thanks.
I switched the starter relat with the a/c relay. A/c fires up, but car doesn't start.
I'm not sure if I'm getting volts
Old 07 Aug 2016, 06:41 am
I actually replaced the switch.
Old 07 Aug 2016, 08:25 am
It doesn't click, fart, burp or anything when you turn the key? Sounds like you have a burnt or broken wire somewhere to me. BUT, I'm NOT a mechanic. I'd start with tracing all of the wiring from the starter to the fuse box and then from the fuse box to the switch. Either that or just run a bypass to the starter and hard wire in a push button.
Old 07 Aug 2016, 08:49 am
Yeah, that was my project for today. I even thought my battery cable might be bad. It would be sweet to find an easily accessible burned wire! It usually doesn't work that way, though....
Old 07 Aug 2016, 10:09 am
Thanks.
I would suggest pulling the starter relay and see if you getting voltage to the starter relay when you turn the ignition switch to start.
Old 07 Aug 2016, 10:56 am
Good point. That would at least show where the problem is in the chain....
Old 07 Aug 2016, 11:23 am
revo's Avatar
Two things you need to do ,with test light or power probe check power wire and signal wire to see if they have power if not trace back till you find power. You already jumped it it works so not ground issue. Good luck keep us posted.
05 PT won't crank aps703 Tech & Performance Forum 4 16 Nov 2015 07:56 pm
No Crank clindley Welcome New PT Cruiser Members 2 09 Jun 2015 09:46 pm
no crank clffkirts Tech & Performance Forum 1 03 Jun 2015 08:46 pm
@002 will crank but will not run jrywb329 General PT Cruiser Discussions 0 01 Jun 2014 10:47 am
