2005 pt cruiser
Old 08 Aug 2016, 02:16 pm
Default 2005 pt cruiser
Im having a heck of a time figuring this problem out. I had check engine light come on. Hooked it up to computer and it said I needed crank shaft position sensor and cam shaft position sensor. Even before engine light came on I knew there was a problem. When I gave it gas at the start, it would start bogging down and jerking at 20 miles per hour then a 40. I replaced the parts and took it for a ride. At first it seemed the problem was solved. Within 5 minutes it started doing the same thing again. I figured it must be when the car starts getting hot,. I figured it might be a wire that was getting hot so I checked the wires. A lot of the insulation had came off because of age and some of the wires coming from the sensors were in areas where they could get hot. I went through and rewrapped the wires with new insulation. Took quite a while because they allow you no room in the engine compartment. That didn't work. By the way, I did take the parts back and got new ones just in case. Put them on, but that didn't work. I am stumped. engine light came back on and computer said same thing. Bad sensors. When the car is first started and I pull out it runs great for 3 minutes. It gets a little warm and start messing up again. Im not a mechanic but do have a working knowledge of engines to an extent. Im stumped. I don't know what else to do, It might be the computer but I just don't want to start replacing parts that it might not need. Does anyone out there know what could be wrong? Im sure its something simple but I don't have enough experience to trouble shoot it. Please help. I don't want to take this to a $100 an hour mechanic for something I can do.Thanks for any suggestions anyone may have.
Old 08 Aug 2016, 02:26 pm
Default Re: 2005 pt cruiser
It takes few minutes to warm up the engine to go into closed loop and the computer takes over, start by making sure grounds and battery terminals are clean and tight. And I hope you reinsulated the bare wires individually.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 08 Aug 2016, 02:29 pm
How many miles are on the engine and does it have an EGR valve? If so, I'd check the EGR valve and see if it's carboned up. You can scrape the carbon off the pintle and check the port where it's mounted and make sure it's clear. If there's a carbon build up in there, you'll need to clean it out too. I also have to ask when's the last time you did a tune up and throttle body cleaning? And finally, where'd you get the sensors? If at a chain parts store like the Zone or Advance, that could still be the problem. I've worked for both in the past and electrical items are the most frequently returned, no good out of the box, items they sell. If possible, get yourself some genuine Mopar sensors and see what happens.
Old 08 Aug 2016, 02:33 pm
Fk5 Fk5 is offline
Does it run well when it is cold? Heat related issues are often wiring or computer related. What codes did the car actually throw? I would search every thread that had the same codes. I would double and triple check all the connectors. Any melting? Did you check the magnets? I believe that some have had trouble with the magnets (which those sensors read) can be damaged and go bad with the heat. Where did you get the sensors? There have been reports of whole batches of those parts house sensors being bad out of the box.
I am considerably cheaper than the next guy, but sometimes you are dollars ahead going with the mechanic. It may be something you can do, but if you can't diagnose it, you can't do it. I am too stubborn to do this myself, but I generally have other cars to use when mine it down. Of course, at that point I am paying insurance for a non-op car so it is probably a bigger waste than the $100/hr mechanic.
2003 GT 5 speed
162,000 miles
Tags
crank sensor/cam sensor
2005 PT CRUISER effecinco Southeast PT Forum 3 05 Jun 2016 10:02 am
Refurbished 2005 PT CRuiser Dream Cruiser Series 4 Convertible soonercruiser craigslist 4 13 Mar 2015 04:10 pm
2005 pt cruiser tbone6675 Tech & Performance Forum 6 12 Sep 2014 08:11 pm
I need help please!! 2005 PT CRUISER Purr0066 Welcome New PT Cruiser Members 1 23 Jun 2012 06:49 pm
2005 PT Cruiser FS TurboDucky Classifieds: For Sale/Trade 0 10 Apr 2012 04:16 pm
