Power Steering easy to turn right hard to turn left
Old 11 Aug 2016, 04:40 pm
Exclamation Power Steering easy to turn right hard to turn left
Hi i have just bought my first PT 4.2 petrol...As i could not test drive it due to it being sworn of the road from no tax i never picked up on the steering problem...The pump makes no sound...You turn to the right and its very easy spin with the hand...You turn to the left and it a bit more tuff. You can still spin it with the hand but you can just feel its much more hard work...If anyone has had this problem pleas shout me as i am a bit lost....Thank you
Old 11 Aug 2016, 05:09 pm
cruserdad1976's Avatar
Default Re: Power Steering easy to turn right hard to turn left
im betting it is a 2.4 in place of a 4.2 odd that it would go one way and not the opther maybe the rack is corroded or damaged on that side
Old 12 Aug 2016, 07:42 am
Have you even checked the power steering level?
Old 12 Aug 2016, 08:38 am
Exclamation Re: Power Steering easy to turn right hard to turn left
Yes all fluid is good. I think i will fire it in to the garage and let them cast a eye over it mainly because it also has a starting problem. You get in start it and do a run in it. Turn it off go to start it again and it will not start. Back the key off and go again and it starts. I am not sure if it maybe the crank sensor or the cam sensor. The crank one looks a right bastard to get to. In that garage they have a computer thing that fires a code at them so i am hoping it will have saved a code and tell us that it is the sensor.
Old 12 Aug 2016, 08:47 am
Fk5 Fk5 is offline
This is probably a tough one to diagnose via internet. Usually I have no trouble making a WAG, but there just isn't enough info. Without knowing just how different the effort is, it could be anything from alignment issues to something being bent and binding or just a sticky rack. Hell, it might be something as simple as tire pressure. I don't believe I have heard of this issue with a PT.
2003 GT 5 speed
162,000 miles
Old 12 Aug 2016, 09:26 am
Is your engine light on?
I would suggest if your engine light is not on to do a battery load test with the battery in the PT Cruiser. Make sure when they do the test to input the correct amps that the battery is suppose to hold.
Old 12 Aug 2016, 02:49 pm
I am having a nightmare day.....The breaks are spongy on it...But then i say spongy i mean the peddle goes to the floor on it... The breaks still work and will stop you dead. But the peddle travels to the floor....So i though i would check to see if there was any air in the breaks. I put a non return valve on the clear tube i used just in case and got the old lady to press the break up and down as i bled them. I did all 4 wheels and a litre of fluid later there was still no air in the system. Now i can only think that the break servo has gone on it...Mine is a 2005....Does anyone no if they suffer with this and if anyone has fitted a new one could you please give me some pointers as to how hard a job it is....Please tell me you dont have to remove the dashboard please dont
Fog lights stay on unless left turn on ladyatwork1 General PT Cruiser Discussions 3 06 Oct 2014 05:23 pm
2006 left turn signal out? Samson Tech & Performance Forum 18 25 Jul 2012 12:44 pm
Had new struts put in, now a noise when I turn either left or right thinkinboutit Wheels, Tires, Suspension 3 19 Dec 2010 11:51 am
Hard Turn PTcruzer02 General PT Cruiser Discussions 2 26 Dec 2008 07:34 am
Poping on left turn. Hotrod Wheels, Tires, Suspension 8 07 Jul 2006 11:31 am
