PO344, timing, rough idle?
Like Tree5Likes
Old 11 Aug 2016, 07:00 pm
crusofthebisquit's Avatar
Default PO344, timing, rough idle?
I had this car worked on for a head gasket last year and it's been one thing after another since BUT....I'm starting to think the mech. may have blew the timing putting it back together.
Anyway to check w/o tearing it down? Got the top cover off but can't find a mark for crank. Lots of searching on here but can't find reference to it with the balancer in place.
It's throwing 344 codes and a new one didn't do anything. It idles rough and looking back....I think it ran better with the blown head gasket.
ain't this boogie a mess
Old 11 Aug 2016, 08:05 pm
Default Re: PO344, timing, rough idle?
Is this issue on your 2003 GT Turbo?
This is the only image I have.
Busted_PT likes this.
Old 11 Aug 2016, 08:17 pm
PTCRUISERSTEVE is correct your going to have to take it apart to confirm timing.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 11 Aug 2016, 08:23 pm
Some members have had wiring harness & wiring problems going to either the camshaft sensor or the crankshaft sensor. I would suggest you take an ohm meter and start checking for a bad wire going to the sensors. I would suggest putting the original camshaft sensor back in the PT Cruiser and start checking the wires.
Remove number one spark plug
Insert long wood rod turn engine tith wrench till rod gets tomthe highest point then see if timing markes are where they belong
Old 11 Aug 2016, 08:30 pm
I put it back in....sure don't see anything. Wiggled a bunch of wires.
Gotta get to both ends to check ohms....don't I?
I don't know diddly about meters, except they check electrical stuff.
Old 11 Aug 2016, 08:33 pm
crazy they didn't put a pointer on the balancer.
Every other vehicle I've had...did.
Yes, even though they're electronic controlled.
Old 11 Aug 2016, 08:55 pm
Aren't these pistons domed?
Feels like that rod is sliding down the face some.
Old 11 Aug 2016, 08:58 pm
looks pretty close though.
hmmm, not far off enough to say it's worth tearing off the whole side anyway.
*@#^. Hoping to see something wrong. Especially with other posts calling out rough idle to bad timing.
Old 12 Aug 2016, 12:03 am
I would suggest using a vacuum gauge for reading, if the belt is off a tooth it will reflect in either a very high idle HG or very low.
An engine that is in good condition will idle between 16-18 steady on most 2.4 engines.
Post what you find.
rough idle after changing timing belt CJDoble Tech & Performance Forum 7 30 Jul 2015 08:59 am
rough idle after timing belt change? 508713 General PT Cruiser Discussions 47 12 Jun 2015 01:33 pm
Rough idle after timing belt replacement we3volsfans Tech & Performance Forum 37 29 Apr 2014 05:17 pm
Rough Idle After New Timing Belt 01SilverPT Tech & Performance Forum 3 20 Sep 2013 07:44 am
rough idle after changing timing belt on 01 pt EnragedDolph Tech & Performance Forum 2 13 Oct 2010 03:51 pm
