AC blows hard when making LEFT turn or downshifting
Old 14 Aug 2016, 02:04 am
Exclamation AC blows hard when making LEFT turn or downshifting
2006 Pt Cruiser 4cyl base model. 81K miles.
I have a very weird issue, my AC blows cold (doesn't blow super hard) and cools inside of car nicely when driving or in idle. But this weird issue happens EVERY time now. When I make a LEFT turn or if I am downshifting into like 3rd or 2nd gear, AC blower blows extremely hard (not sure if it is suppose to be the normal hard as compared to how it blows when driving or idling).
When its hot outside, I get to the point where I look forward to left turns or downshifting as I'm driving.
I cannot find this particular issue online and I am usually very good with using google.
As far as car, it drives wonderful and has been actually very reliable.
Anybody have an idea what this could be? I would like it to blow like it does during left turns and downshifting to lower gears all the time. I sure hope someone can point me in the right direction.
Old 14 Aug 2016, 01:26 pm
_PTGT03's Avatar
Default Re: AC blows hard when making LEFT turn or downshifting
maybe some loose or broken contacts inside the switch that move about with appropriate forces are applied. i would recon to take out the hvac control switch and try to have it replaced with one from the auto-wreckers ?
Old 14 Aug 2016, 09:25 pm
So the control panel switch perhaps? Now one thing I may try is to see if the same thing happens when the heater is on, as I have not done so yet. Anything else it could be?
Power Steering easy to turn right hard to turn left Rodger_Le_Bonk Tech & Performance Forum 6 12 Aug 2016 02:49 pm
Front-Left Wheel making a lot of noise TheDarkAvengerX Wheels, Tires, Suspension 6 11 Mar 2013 01:45 pm
My PT downshifting hard! edj8 Tech & Performance Forum 24 19 Mar 2010 12:36 pm
Noise in front when making left turn; not right Runkle Wheels, Tires, Suspension 2 12 Feb 2007 01:04 pm
Chirping sound while making right and left turns ptcignaboi Tech & Performance Forum 14 19 Apr 2003 09:30 pm
