Oil light
Old 17 Aug 2016, 09:41 am
Default Car hesitate ???
I'm having trouble with my 05 pt turbo when I start the car I have to rev the engine every time if I don't as soon as I put the car in drive it will drive a short distance but then it starts to hesitate I push on the gas and the car wont go. I have to put the car in park and rev the engine then it will go . This only happens when I first start the car after that it won't do it again I'm puzzled any help out there ?? The oil light turns on and off at times I'm not sure if that has anything to do with it but I change the oil on time every time
Old 17 Aug 2016, 10:02 am
Default Re: Oil light
A few suggestions to start with.
Check for DTC's
Check all hoses connected to the intake or uses a vacuum draw from the intake system.
Clean or replace the IAC
Replace oil pressure sender
ABS Light, Parking Brake Light, Traction Control Light kupothechocobo General PT Cruiser Discussions 9 28 Feb 2017 01:56 pm
Left Side Break Light / Blinker / Reverse Light MaxJoseph Tech & Performance Forum 6 07 Nov 2015 05:18 pm
Showing ABS light, Brake light, Traction light on Dash fox50h Tech & Performance Forum 19 18 Feb 2014 11:40 pm
Check engine light: Amber Light: power loss dbleclk Turbo Performance 2 06 Jul 2011 06:12 am
Mork's Tail Light and Reverse Light Tint Progress Morkeste Exterior Accessories Forum 30 23 Jun 2011 12:20 pm
