2006, Security screw size for ignition assembly to column ?
Like Tree6Likes
Old 18 Aug 2016, 05:30 pm
Question 2006, Security screw size for ignition assembly to column ?
Hello all, im werkin on me mums 06 cruiser and replacing the ignition assembly.
What is the size/type of security bit i need for the 2 large button head bolts that hold it on to the column on top ? I wasted $30 on a 130 pc security bit set and none of em fit. I guess i will drill em out the i will need to know what size bolts i would need to replace em. Would rather not have to drill em out .
Old 18 Aug 2016, 06:22 pm
LionPT's Avatar
Default Re: 2006, Security screw size for ignition assembly to column ?
I haven't replaced it, but I have it written down that it is a T30.
Old 18 Aug 2016, 07:09 pm
VsandFords's Avatar
Welcome to the forum.
Old 18 Aug 2016, 08:26 pm
Old 18 Aug 2016, 09:34 pm
T30 Torx Tamper Proof ?
That one is in the set i have but it dont fit. THose are a 6 point bit, the bolt head looks to be a 5 point tamper of some sort.
Old 18 Aug 2016, 09:35 pm
Thankx !
Old 19 Aug 2016, 06:01 am
LionPT's Avatar
CRV T-30 is 5 point.
Old 20 Aug 2016, 04:02 pm
Finally got the darn thing off, boy those are some tough bolts to drill out !
HOw do i pull out the ignition cylinder from the housing ? i see plenty of infos for 01-05 but not 06 up.
I was hoping to just switch out the current cylinder with the replacement ignition assembly and re hook up the old security ring/box to avoid having to pay to have ecm programmed to the new key n immobilizer.
Old 20 Aug 2016, 05:11 pm
LionPT's Avatar
All I have is a pic another member posted.
Old 20 Aug 2016, 05:27 pm
rob302's Avatar
the peg in the center of the torx will break off with little effort and leave you a normal torx. put a flathead or small punch against the peg on an angle and tap it with a hammer. so easy it's stupid. try it
wiper fluid reservoir screw size trtrtr607 General PT Cruiser Discussions 1 22 May 2016 06:42 am
2006 ignition security bit bluefalcon1 Tech & Performance Forum 2 12 May 2016 08:35 pm
Steering column ignition parts bro Tech & Performance Forum 2 02 Jun 2013 06:14 pm
2006 ignition shroud screw size? Samson Tech & Performance Forum 1 22 Apr 2012 10:37 pm
Need Dash Tweeters Measured Screw to Screw- MoparHemiPower Sound and Security Forum 3 13 Sep 2011 06:41 pm
