Ecu and key questions
Like Tree2Likes
  • 1 Post By myckee
  • 1 Post By chuzz
Old 19 Aug 2016, 05:34 pm
Default Ecu and key questions
I finally figured out my ecu took a crap, I have a donar car with a good computer and key. Both cars are 1st gens non turbo automatics.
Questions:
Can I take the ecu, key and lock cylinder out of the donar and install into my car with out any issues?
Will I have an issue with the transponder communicating at all with the different parts.
1999 C3500 Dually 454ci
2002 PT Cruiser Touring L4
2008 Trailblazer L6
27T Roadster 555ci BBC
Old 19 Aug 2016, 06:28 pm
Default Re: Ecu and key questions
I did that with my 06 (second Generation) and it worked.
Surprising enough it didn't eneven throw a code for wrong VIN
I stand corrected, I forgot about the SKIM module.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 19 Aug 2016, 06:38 pm
Would it just throw a code or will it disable it too?
2008 Trailblazer L6
Old 19 Aug 2016, 07:28 pm
Questions:
You need to swap over the ECU, key+lock cylinder, and, the skim module. Once you swap all three pieces, it will not throw any codes at all.
JoeX likes this.
Old 19 Aug 2016, 08:18 pm
where is the skim module?
2008 Trailblazer L6
Old 19 Aug 2016, 08:24 pm
sry premature,i looked it up. thanks for the good info guys, you all are the best as always
2008 Trailblazer L6
Old 22 Aug 2016, 09:14 am
Trillion's Avatar
Location: The place where the Game of Thrones accent comes from.
I still don't have a PT but from the previous cars I've had why do you need to change the lock barrel?
Won't it just be the keys transponder that's paired to the electronics not the blade?
In the UK looking for a 2006 or newer CRD!
Old 22 Aug 2016, 09:29 am
Handy_Cruiser's Avatar
You will need the PCM, the SKIM module and the sentry key all from the donor car to make this work. To avoid having to change the cylinder in your PT, you can just take a zip tie and fasten the sentry key to the ring to the SKIM module under the column cover. Then you can use a non-sentry copy of your original sentry key to start your PT.
Here's some photos of the SKIM module from my 2001 Limited:
Old 22 Aug 2016, 09:40 am
Trillion's Avatar
I'd try bonding the transponder chip to the inside of the plastic cover/housing so in the event of an attempted theft the first thing the thief does is to smash the plastic off to get at the wires and they throw the plastic cowling in the back out of the way and they would then unbeknown to them be immobilising the car
Old 22 Aug 2016, 12:18 pm
I zip tied my transponder key to the module that Handy posted a picture of. That way, I have extra keys I can use. I got 3 keys cut at Walmart for a couple of dollars each. My son, wife and I all have a key.
Handy_Cruiser likes this.
Want another PT - few questions tlturbo General PT Cruiser Discussions 9 15 Sep 2012 07:42 pm
03 2.4 questions pluminator Wheels, Tires, Suspension 10 02 Jun 2012 02:18 am
2 more questions..noobe questions.. BarbieCar General Turbo Discussions 9 20 May 2012 07:32 pm
2 questions.... Stace22 Tech & Performance Forum 12 11 Jan 2011 10:44 am
Questions Questions..newbie DaShado PT Cruiser Convertible Forum 0 01 Apr 2006 12:22 am
