WHAT SHOULD COMPRESSION BE
Like Tree2Likes
  • 2 Post By ptcruisersteve
Old 20 Aug 2016, 11:10 am
Jdhaulr1's Avatar
Question WHAT SHOULD COMPRESSION BE
Hello everyone, I just purchased a 2005 PT Cruiser Convertible Touring Edition turbo, I know the turbo is bad but I want to run a compression test just to double check for any other problems, what should the 2.4 turbo compression be?
Old 20 Aug 2016, 11:28 am
Default Re: WHAT SHOULD COMPRESSION BE
I'll let someone with more knowledge of that chime in as I've seen numbers from 105psi to 180psi which all depends on the ware and tear of the internals. Whatever you come up with, all for cylinders should be within +- 10% of each other. If one is low then you have a problem.
Old 20 Aug 2016, 11:32 am
Jdhaulr1's Avatar
I just found my answer under "compression" topic forum, I tried to search for it but was unable to type anything into the search window? ? I really like my Cruiser and I know this forum will be extremely helpful! Thank you!!
Old 20 Aug 2016, 11:35 am
Jdhaulr1's Avatar
Thank you CRUZIN! BTW I have 175psi across the board! Very happy about that!
Old 20 Aug 2016, 11:38 am
This data is for a 2002 2.4 engine
Jdhaulr1's Avatar
SORRY! I MEAN CREWZIN!
Old 20 Aug 2016, 12:12 pm
This should be taken with the engine cold and the TB wide open. You need to also make sure that the same engine rotation count 4 or five is done on each cylinder when checking the compression. Then you compare the results. The highest cylinder would be your guide and all other should not be more then about 10%max.
Did you do the maximum five count cycle on all cylinders?
NitroPT and chuzz like this.
Low compression? devindinapoli General PT Cruiser Discussions 28 29 Jun 2018 04:34 pm
Compression Papa2448 General PT Cruiser Discussions 12 10 Jan 2016 12:15 am
Compression VS Compression Ratio scatgo1 Tech & Performance Forum 2 18 Oct 2015 08:19 pm
compression psi moonshinehd Tech & Performance Forum 7 27 Apr 2012 10:03 pm
Compression ptnut Tech & Performance Forum 12 21 Nov 2011 11:40 am
