2002 cruiser vaccum hose problem.
Old 20 Aug 2016, 12:31 pm
Default 2002 cruiser vaccum hose problem.
Having an issue with the vacuum hose that is connected to the throttle body. Whenever that hose is connected, the engine stalls, but when the hose is disconnected its runs fine. I don't know what exactly that hose runs to.
Your help would be much appreciated.
Old 20 Aug 2016, 12:33 pm
Default Re: 2002 cruiser vaccum hose problem.
Welcome to the forum
Is your engine light on? If so what is the engine trouble code? Do you have an OBDII Scan tool?
Was the timing belt recently replaced? If so check to see if the timing belt is off by one tooth.
How many miles on the PT Cruiser?
What parts have been replaced so far?
Old 20 Aug 2016, 01:32 pm
Handy_Cruiser's Avatar
First, welcome to the forum from the great sovereign state of Arkansas!
Now if I understand the issue, the PT runs with the hose disconnected but dies with the hose connected?
If so, my first inclination would be that the Idle Air Control (IAC) valve is stuck closed. This valve meters air for the engine to idle. If stuck in the closed position, the engine may choke when at idle with the butterfly closed. Removing a vacuum line attached to the throttle body might allow enough air in to keep the engine running.
For me, I would first check the trouble codes as others have mentioned. Those codes, if present, may indicate another issue. However, if I found nothing to indicate something else, I'd likely remove the throttle body and the IAC valve. Then I would clean them really well with carb cleaner of some type assuring the IAC valve was not stuck. Then I'd reassemble and see if the engine runs as it should.
Again, check the codes and any other indicators before removing throttle body. I am only going off what you've said so far.
Old 20 Aug 2016, 01:41 pm
My response is pretty much might be what the other 2 members said ...except I would be careful using anything except chemical cleaners made for electrical parts. Some chemical cleaner may damage the IAC.
Old 20 Aug 2016, 01:52 pm
2002 cruiser sunroof problem lowfiero General PT Cruiser Discussions 2 09 Apr 2015 09:29 am
2002 PT Cruiser Horn Problem Druck Feedback and Support 2 27 Jul 2014 12:59 pm
URGENT: 2002 PT Cruiser 2000cc Limited speedo problem scots1 Tech & Performance Forum 5 30 Mar 2013 11:09 am
2002 Cruiser OBDII Problem justinbowser Tech & Performance Forum 10 27 Apr 2011 09:37 pm
2006 GT - Swapped Engine Vaccum Hose problem wendelltu General Turbo Discussions 8 12 Aug 2010 05:12 am
