gas cap code 0440
Like Tree2Likes
  • 2 Post By chuzz
Old 21 Aug 2016, 04:24 pm
Default gas cap code 0440
03 pt turbo
i keep getting this code 0440 it says gas cap
can anybody fill in the blanks
is there any short cuts to fix this problem
can i clean it with some cleaner to open up the pressure release like some carb cleaner i have a gallon or spray
if this is need of replacement i mean i got 12 for a new one
i got this pt cruiser running great and the ac started to work now i was only asking 3500.00 not many calls this week
i know a turbo is a way to go so much more power than the non t
Old 21 Aug 2016, 04:49 pm
Default Re: gas cap code 0440
Your kind of talking in circles here. I take it your trying to sell it but you want to get rid of the P0440 code. Usually, that code pops up after filling up the gas tank and the cap isn't turned at least 3 clicks to make sure it's properly closed. It also takes a number of starts for that fault light to go away, unless there's something else wrong like a worn gas cap that isn't sealing properly.
Old 21 Aug 2016, 04:59 pm
your right i am selling it
but with the check engine light it is a turn off to buyers
i will give it a try 3 clicks to make sure it sealed right
prices have dropped a little
thanks so much i am always interested in saving money
thanks again
Old 21 Aug 2016, 05:12 pm
rckstein's Avatar
Is this what's in the Owner's Manual for the Gen1?
I know it's a Gen1 that the OP is selling, but for my Gen2 this is what is stated in the Owner's Manual regarding gas cap tightening:
"NOTE: Tighten the gas cap about 1/4 turn until you
hear one click. This is an indication that cap is properly
tightened."
I've seen some people really crank on their gas cap. I use to do more than one click, but I'm on about my 3rd gas cap on my PT, and I use the locking MOPAR one, and they are kind of expensive, so no more than 1 click. My PT doesn't like the after-market ones like a Stant, as it keeps setting off the Gas Cap code. I had the gas cap code a couple of months ago and a new MOPAR cap solved the problem.
Old 21 Aug 2016, 05:20 pm
We've been saying "3" for a few years now mostly just to be sure it's on. The Owners Manual for the Gen 1 does say one click and 1/4 turn but on mine (original cap) 1/4 turn = 3 clicks.
Old 22 Aug 2016, 08:59 am
When mine threw that code, I removed the cap's O-ring and cleaned the groove it fits in, cleaned the O-ring and sprayed it with some WD-40. I then cleaned the filler neck and put it back on. I then cleared the code with my OBDII scanner. It has NOT come back since doing this. I also click my cap 3 clicks after putting gas in it.
P0420 code Converter Code? 2008/110,000 miles Sarasmiles Tech & Performance Forum 8 28 Mar 2014 07:08 pm
My 340 code is now 344???????????? jbander General PT Cruiser Discussions 2 03 Aug 2013 03:29 pm
Error Code 0551,0440 ilzho Tech & Performance Forum 1 25 Feb 2013 07:11 pm
CODE P0339 NOW, NOT "ALL" FIXED CODE YET HarleyTom Tech & Performance Forum 0 14 Nov 2012 03:23 pm
error code 0440 lt4supr General PT Cruiser Discussions 1 17 Dec 2008 05:48 am
