click photo for more pictures LOWER CONTROL ARM (WISHBONE) BUSH SET
Like Tree3Likes
  • 1 Post By chuzz
  • 1 Post By rcktpwrd
Old 24 Aug 2016, 10:17 am
whiteclaw's Avatar
Default click photo for more pictures LOWER CONTROL ARM (WISHBONE) BUSH SET
Energy Suspension bush kits for the Chrysler PT Cruiser and Neon
Anybody bought these?
So I bought them, went to garage number 3 who says same thing as other 2 garages, they do not fit the Pt cruiser. They do not even look like the original set on the cruiser.
Chrysler PT Cruiser 2001, Automatic, No Mods, Right hand drive. 2.0
Old 24 Aug 2016, 10:38 am
Default Re: click photo for more pictures LOWER CONTROL ARM (WISHBONE) BUSH SET
Rather than go through all that crap, I just bought the entire Lower Control Arms from rockauto. They're Moog brand and I had no problems installing them. They make a huge difference in the ride and handling. Good luck with that stuff.
Carnut likes this.
Old 24 Aug 2016, 11:20 am
VsandFords's Avatar
After reading the add and seeing the picture. I believe they will work. The shops you are going to apparently are not familiar with the aftermarket urethane and the design change. The directions that should come with the kit should give you the info to do it yourself. If you are so inclined.
Old 24 Aug 2016, 04:52 pm
rcktpwrd's Avatar
I agree with VsandFords.
I installed the complete Energy Suspension master kit in my PT. The vertical bushing is a completely different design from the OEM bushing. Mine was three pieces plus the metal sleeve.
They aren't that hard to install, just takes a bit of fiddling...
VsandFords likes this.
Joel
www.rcktpwrd.com
Old 25 Aug 2016, 07:50 am
whiteclaw's Avatar
Do they last a long time?
I bought this particular make for all the bushes, anti roll bar links etc OEM ones do not seem to last very long here which is why I tried these.
I may ask a friend to do these bushes, he is pretty good. They do look quite different from the ones on the car.
Old 25 Aug 2016, 04:25 pm
rcktpwrd's Avatar
Cool Re: click photo for more pictures LOWER CONTROL ARM (WISHBONE) BUSH SET
They should last longer then the OEM ones... I have 50,000 or so miles on mine and they seem to still be just fine. Be sure to use plenty of the lubricant for the poly bushings.
Joel
www.rcktpwrd.com
rear wishbone bolt davesquire Europe PT Forum 6 02 Nov 2015 05:12 pm
Do I need a new lower control arm? hokeyeye Wheels, Tires, Suspension 3 26 Aug 2013 09:13 pm
Will not start click click driver window goes down Fe2orr General PT Cruiser Discussions 5 19 Feb 2013 05:12 pm
Pictures of Control Arm - How's it Look? falconut Wheels, Tires, Suspension 39 03 Feb 2013 11:50 am
Lower control arm LNBNDN Wheels, Tires, Suspension 2 29 Jun 2011 10:00 pm
