Ignition coil torque specs
Like Tree5Likes
  • 3 Post By rckstein
  • 1 Post By wwpptc
  • 1 Post By NitroPT
Old 24 Aug 2016, 08:56 pm
Question Ignition coil torque specs
I'm replacing the ignition coil. I have a 2006 PT cruiser, n/a, type b. What are the torque specs for the coil bolts?
Thank you
2006 PT touring edition, 5 spd manual, 140K, MSD 8.5 mm wires, Champion plugs
Old 24 Aug 2016, 09:04 pm
Default Re: Ignition coil torque specs
I looked through the Haynes manual and couldn't find any specific torque specs for the coil.
Old 24 Aug 2016, 09:14 pm
I couldn't find any either. just tighten without over tightening?
Old 24 Aug 2016, 09:23 pm
rckstein's Avatar
Thank you
In my Service Manual:
"Ignition Coil to Cyl. Head 105 in. lbs."
Old 24 Aug 2016, 09:43 pm
To the OP ---- Take note that is stated in inch lbs.
Jerry
rckstein likes this.
Old 24 Aug 2016, 10:18 pm
Thank you!
Old 25 Aug 2016, 08:17 am
When in doubt you can simply look at the any torque value chart for specific fastener.
Simply search:
Torque values of bolts
FYI although I am a stickler for "BY THE BOOK" installation instructions in this case I would recommend NOT to go as tight on the plastic coil pack as indicated. Instead use a little loc-tite blue.
LCA Torque Specs chuzz General PT Cruiser Discussions 4 29 Mar 2016 11:53 am
Torque Specs UZ4PLAY Tech & Performance Forum 15 02 Aug 2012 12:30 pm
torque specs gokart Tech & Performance Forum 2 15 Apr 2009 01:46 pm
torque specs? youngcruiser Tech & Performance Forum 8 21 Mar 2006 03:49 pm
Torque Specs irelandmoss Tech & Performance Forum 2 18 Jan 2006 09:07 am
