Boiling coolant
Old 27 Aug 2016, 02:43 pm
Angry Boiling coolant
So I drove home from work and when I got the stop sign by my house I heard a sound like boiling water and the temp gauge was about 3/4 of the way to the red line
so I pulled into the house turned the car off and popped the hood and the coolant overflow was shaking
called my dad he said it could be the thermostat or the head gasket
did a compression check and everything runs around 155 psi
however there was oil by the first cylinder when I pulled the spark plug out
any ideas guys??
Old 27 Aug 2016, 02:52 pm
Default Re: Boiling coolant
Welcome to the forum
Old 27 Aug 2016, 02:58 pm
Welcome to the forum from Ventura, Southern California
What year is your PT Cruiser?
How many miles on the engine?
Is your radiator fan working?
Old 27 Aug 2016, 03:17 pm
Welcome to the forum.
There are several reasons for the coolant to reach the boiling point but the most common, as was already asked, is that the radiator fan isn't working properly. Trapped air in the system can also cause this, usually from loosing coolant which is replaced by air.
If the temperature gauge goes back to normal (half way) when driving on the highway but starts to raise towards the red line when slowing down or stopped, that almost a sure sign of a bad radiator fan.
Old 27 Aug 2016, 04:45 pm
so throw the plugs back in put the manifold back on and give it a drive?
Old 27 Aug 2016, 04:50 pm
That is not the advise that was suggested.
I would re-read ptcruisersteve and CREWZINs response to you again.
Old 27 Aug 2016, 05:22 pm
At this point I would suggest manually checking the radiator fan to make sure the low speed and the high speed are working before doing anything else.
Old 27 Aug 2016, 05:24 pm
02 pt cruiser
180k
one front end wreck
however it was working properly until yesterday
only other thing wrong is it needs a wheel bearing
Old 27 Aug 2016, 06:01 pm
Just apply 12 volts from the battery to the low speed and high speed on the radiator fan after you unplug it and let us know what you find out.
Old 27 Aug 2016, 07:24 pm
I had that happen with mine. A new thermostat, radiator cap and line to the overflow jug, took care of it. The cap was actually the real culprit. It wasn't holding enough pressure.
Overheating and boiling coolant Sunshine5 Tech & Performance Forum 2 17 Aug 2014 11:42 am
2004 PT Boiling Over Help 2004 Tech & Performance Forum 10 18 Dec 2010 01:43 am
Coolant Boiling Over jorgesag Tech & Performance Forum 6 10 Oct 2010 10:15 pm
Car is off, Boiling Coolant ptcruzrmama General PT Cruiser Discussions 17 15 Aug 2010 12:21 pm
Boiling over - not overheating ionheavens General PT Cruiser Discussions 12 19 Jan 2010 12:01 pm
