03 Touring Edition P0462
Old 04 Sep 2016, 11:40 am
Default 03 Touring Edition P0462
Here's the run down. Had P0462, mechanic put in new fuel pump. Then had to run new wire to power pump. Still have P0462. Have also put in new PCM with now change. Another issue that I don't think is related but who knows is radio works fine unless key is jarred out of cylinder even slightly then screen goes off and no sound out of speakers but you can still hear CD player as it changes dics. Push key back in and radio works perfectly.
Old 04 Sep 2016, 01:33 pm
Default Re: 03 Touring Edition P0462
P0462 - Fuel Level Sending Unit Low Voltage Conditions
Possible Causes:
1. Faulty fuel level sensor
2. Fuel level sensor harness is open or shorted
3. Fuel level sensor circuit poor electrical connection
The PCM has detected the fuel level as being more than 100% for more than 4.5 minutes and triggered the P0462 code.
I would suggest checking the fuel level sensor harness. Its a shame that when the wire was replaced for the fuel pump that the fuel level sensor wires were not checked at the same time. Physically check it from the PCM to the fuel tank and make sure its not rubbed through shorting to ground or open.
P0462 Fuel Sender Voltage jbond Tech & Performance Forum 8 03 Apr 2016 05:38 pm
05 Touring Edition. Fan whitec1001 Tech & Performance Forum 8 13 Apr 2013 07:12 pm
02 Touring Edition For Sale mrsdemas Classifieds: For Sale/Trade 8 14 Nov 2012 12:47 pm
06 Touring Edition - 68k - Arkansas cjhath87 Classifieds: For Sale/Trade 0 01 Jul 2010 09:16 am
"Touring" edition/ please post turbomangt General PT Cruiser Discussions 1 13 Feb 2003 05:48 pm
