Issue with the rad fan
Old 04 Sep 2016, 02:34 pm
whiteclaw's Avatar
Default Issue with the rad fan
So I thought it had gone kaput, car overheated the other day but was idling for ages and no sign the fan was working at all. Tried the car again, and no fan came on, however, car never overheated and then I heard it and could see it working again.
So my guess is, one of the relays maybe gone? I replaced the slow fan relay today, ordered the one for the high speed.
I had a code 1489
Chrysler PT Cruiser 2001, Automatic, No Mods, Right hand drive. 2.0
Old 04 Sep 2016, 02:54 pm
Default Re: Issue with the rad fan
I had a code 1489
My guess is that you will be changing the fan shortly, when they are about the end of the life (brushes about gone) they will work les and less...
IHO
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 04 Sep 2016, 03:12 pm
P1489 - High Speed Radiator Fan Relay Circuit Malfunction:
Possible Causes:
1. High speed fan radiator relay control circuit is open or shorted to ground
2. High speed fan radiator relay power circuit is open
3. High speed fan radiator fan relay is damaged or has failed
4. PCM has failed
I am suggesting you check the wiring going to the high speed relay. Physically make sure the wiring is not touching ground or has cracks in it. You might just have a faulty high speed fan relay.
A/C Issue geeminator Tech & Performance Forum 1 21 May 2016 01:34 pm
Fan Issue mopardude Tech & Performance Forum 2 05 Apr 2012 05:22 am
AC Issue - Help if possible falconut Tech & Performance Forum 13 19 Aug 2011 12:40 pm
HID issue ilee941 Exterior Accessories Forum 3 12 Mar 2011 09:10 pm
A/C issue. hermtm2 General PT Cruiser Discussions 9 26 Jul 2008 08:40 pm
