Limp mode and code p0765
Old 05 Sep 2016, 12:22 pm
Default Limp mode and code p0765
Hello,
2001 PT cruiser 125k on it, my nephew bought it in limp mode and with the p0765 code. the solenoid valve was changed and made no difference. no fuses have been blown and the relay has checked out OK.
Is there a common issue with this that I should be looking for at the start? and is there a common diagnostic process to eliminate components?? thanks for any insight.
Old 06 Sep 2016, 01:51 am
_PTGT03's Avatar
Default Re: Limp mode and code p0765
strange. in my 03 manual they don't even have a 765 code to look up. i can only get 700 and 703
which are related to the brake switch fault, and a transmission code, respectively.
Old 06 Sep 2016, 01:55 am
P0765 - A/T Underdrive Solenoid Circuit problem:
Possible Causes:
1. Underdrive Solenoid control circuit is open or shorted to ground
2. Underdrive Solenoid control circuit is shorted to system power
3. Underdrive Solenoid is damaged or has failed
4 .TCM or PCM has failed
The underdrive clutch solenoid valve is turned on or off by the Transmission Control Module in response to signals sent from the park/neutral position switch, vehicle speed and Engine Control Module.
trouble code p0882 limp mode eli PT Cruiser Convertible Forum 6 02 Nov 2016 03:20 pm
Limp Mode? Bentron General PT Cruiser Discussions 23 21 Jun 2016 10:54 am
Limp Mode....? CluelessKate Tech & Performance Forum 6 11 May 2016 11:51 am
intermittent check engine light showing no code and limp in mode funkyfred General PT Cruiser Discussions 12 26 May 2013 10:55 am
pt cruiser in limp mode code 0339 torsotext Tech & Performance Forum 2 19 Mar 2011 09:31 am
