Whining Engine Noise 2002 PT Cruiser 2.4 DOHC
Like Tree4Likes
  • 2 Post By JoeX
  • 1 Post By XJollyx
  • 1 Post By XJollyx
Old 06 Sep 2016, 02:43 pm
Default Whining Engine Noise 2002 PT Cruiser 2.4 DOHC
Hey All,
My daughter is having an issue with her car. It's an 02 PT Cruiser 2.4 DOHC non turbo 140k miles. After it warms up it whines, sometimes pretty loud. Its directly proportioned to the engine speed. Doesn't matter what gear the tranny is in, no slipping, fluid looks good. It doesn't matter if the car is moving or not. It doesn't change at all when you turn the wheel and doesn't sound like the power steering pump. It's not a serpentine belt slip. Alternator is charging good. Sounds like it's coming from the timing belt area. The timing belt has around 50k Mike's on it. You guys got any ideas??
Old 06 Sep 2016, 03:05 pm
Default Re: Whining Engine Noise 2002 PT Cruiser 2.4 DOHC
Take the belts off one at a time and see if it gets quiet. Being that they are all in the same area its difficult to just listen and determine which bearing or belt is bad.
ptcruisersteve and Gkon like this.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 06 Sep 2016, 03:12 pm
Great idea. I will try that.
Gkon likes this.
Old 06 Sep 2016, 10:21 pm
_PTGT03's Avatar
easiest would be to remove thw accessory drive belt. then you can determine if it is a timing belt system or the alternator, ac and power steering.
Old 06 Sep 2016, 11:22 pm
VOS's Avatar
VOS VOS is offline
My '01 with less than 65k miles on it had the idler going out when I had the timing belt changed.
Follow the steps given for the external belt and if the noise doesn't go away, it might turn out to be the idler or tensioner for the timing belt causing it.
Old 07 Sep 2016, 05:00 am
_PTGT03's Avatar
great suggestion. i had the same symptom on a pontiac sunfire i used to own ! it was the idler
Old 10 Sep 2016, 11:18 pm
UPDATE not the accessory drive belt or anything it turns. It has gotten louder and sounds like the tranny is starving for fluid. That makes sense since it now doesn't start the noise until you drive it, even when the car us at operating temperature. No slipping or hard shifting still. I believe the torque converter has partially come apart, blocking the fluid intake through the filter. Hopefully I caught it before the tranny is completely toast. No way to tell but to drop the pan and take a look. May still rebuild the tranny over 150k and metal isn't a good mix. Any thoughts?
Gkon likes this.
Old 11 Sep 2016, 02:02 am
It wouldn't hurt if you could get a scanner tool that reads the transmission codes to see what codes come up.
Old 11 Sep 2016, 02:04 am
No codes
Old 11 Sep 2016, 07:10 am
How about just trying a trans fluid and filter change? Does the fluid look foamy on the trans stick after the car warms up? If so, you may have a slight leak in a hose that's sucking air. IDK, I'm not a mechanic. Just making a suggestion.
Whining Noise siddharta1979 General PT Cruiser Discussions 7 04 Dec 2013 09:51 pm
2002 2.4L DOHC PT Cruiser Head Gasket tazman3 Tech & Performance Forum 4 17 Aug 2013 01:14 pm
2002 PT Cruiser with 126,000 miles is making a whining noise. WHat is it? Evelyn Tech & Performance Forum 3 18 Dec 2012 06:31 am
whining noise estrada Tech & Performance Forum 3 02 Jan 2011 08:56 pm
Whining noise from engine Leroy Tech & Performance Forum 6 27 Dec 2010 01:52 pm
