Urethane Motor Mount Inserts!
Like Tree12Likes
Old 06 Sep 2016, 08:00 pm
Default Urethane Motor Mount Inserts!
Wow...I didn't think anyone made these. I know I'm tired of replacing the rubber ones. Source is 'Aftermarket Suspension Parts. com' #41906 Upper & Lower 01-10 @$23.97. Thought someone could use the info.
njsteve1 and Gkon like this.
Old 06 Sep 2016, 08:09 pm
War_Eagle's Avatar
Default Re: Urethane Motor Mount Inserts!
Nice info, thanks.
2005 Silver GT, auto, black leather, HID Headlights, ST Front sway bar, 215 45/17 tires, dark tinted front windows, stock running gear, sickspeed black pearl shift knob.
Old 16 Sep 2016, 04:30 am
Modernperformance.com has them also
Old 16 Sep 2016, 08:44 am
You should do a little more reading about them before jumping on spending your money getting them?
From your past postings about what you are doing and how your PT Cruiser is IMHO you are not going to like them.
And if it is something that you want to do there are better alternatives.
Old 16 Sep 2016, 11:37 am
Handy_Cruiser's Avatar
I don't have the prejudice against polyurethane bushings that some folks have. And I tried a set of these same #41906 motor mount inserts as well. They were great at speed, but below 1000 rpm, they caused serious vibration in my 2005 GT Stage 1 with auto transmission. Idle and reverse were the worst.
These may have some advantage for performance. But based on my experience, they really aren't practical for an everyday driver PT with an automatic transmission. Some say that they are not as bad with a manual tranny, but I can't confirm that.
And one more thing. Since they cheap, it might seem fun to just try them on a lark to see what you get. However once pressed into new engine mounts, they are difficult to remove and can damage the rubber in the mounts. After my trial with the inserts, I went ahead and just installed another set of new mounts.
rob302 likes this.
Old 16 Sep 2016, 12:03 pm
Any inserts that fit into factory mount will increase engine vibration and firmness. This could cause other engine mounts and parts to break. Also it has long been proven that using these type of does give an unpredictable engine reaction under extreme load.
Most mounts even a "TRUE" *solid mount (*there are none for a PT Cruiser) will be smooth at speed. This is when the engine and transmission are in a neutral set position.
As I suggested member thinking about using these should read more about them before perhaps spending money on
BTW to be clear I have several of these inserts I have used and even have around the garage. Been their done that wont do it again. There are better ways.
Pictures available if requested.
Last edited by NitroPT; 16 Sep 2016 at 12:32 pm. Reason: Moderated post now back to my approved words
Old 16 Sep 2016, 12:30 pm
red98gt good luck with your continued discussion on mounts.
Handy_Cruiser likes this.
Old 16 Sep 2016, 12:49 pm
Are you doing the alignment procedure that is specified in the factory manual when you replace your upper and lower strut mounts! Other members have replaced the strut mounts every 8 to 10 months average until they did the alignment procedure.
Old 16 Sep 2016, 12:52 pm
rob302's Avatar
Aaahahhahaaha I remember that thread... And my contribution
Vibration at Idle with Prothane Motor Mount Inserts
Old 16 Sep 2016, 12:58 pm
That one was TRUE classic. If there was a PTCruiserLinks hall of fame, that one should definitely be there.
about motor mount inserts. MoonWalker General Turbo Discussions 10 30 Apr 2013 04:48 pm
Motor mount inserts NicksCruiser Tech & Performance Forum 6 17 Apr 2012 07:50 am
NEW urethane Filled Motor Mount chevy2inreno Classifieds: For Sale/Trade 1 24 Mar 2010 02:24 pm
prothame motor mount inserts 1quickpt Turbo Performance 3 22 Jan 2006 11:17 pm
F/S:Motor Mount Inserts JSTANEON Classifieds: For Sale/Trade 1 11 Mar 2004 10:26 am
