2006 base model making noises
Old 07 Sep 2016, 12:51 pm
Default 2006 base model making noises
I dont really know how to explain my problem. The car used to idle rough but ive changed plugs wires and engine mounts. I know longer feel it running rough but it still makes the same noises. It almost sounds like a sputtering/grinding noise but it only happens intermittently. Also it only occurs when the car is in D. I have no idea what to change next
Old 07 Sep 2016, 07:31 pm
Default Re: 2006 base model making noises
Take it to an autozone and ask them to run the computer codes for you. Post any codes that come up here. We'll try to help you. About the only thing I can suggest right now, is to remove the drive belts and spin some pulleys and see if you can locate it that way. Depending on the miles, you could simply have an idler pulley going bad. After all, the car IS 11 years old now.
Old 07 Sep 2016, 07:51 pm
Are the sputtering/grinding noise at a certain engine rpm or only at an idle when in drive?
Give us any details that might help determine where this sputtering/sputtering noise.
2006 PT Base Model Washer Tank Leak NightWing General PT Cruiser Discussions 5 06 Oct 2015 04:29 am
How do I add a new site for front speakers? 2006 base model funkyfred Sound and Security Forum 4 02 Oct 2015 02:14 am
2006 base model wont start jclayton973 Tech & Performance Forum 7 26 Jan 2014 04:15 pm
towing with 2006 base model turtle General PT Cruiser Discussions 7 03 Jul 2013 10:11 pm
2006 Base Model Window Switch problem bobgengeskahn Interior Accessories Forum 4 04 Jun 2010 06:57 pm
