Blue Devil Head Gasket Sealant
Old 09 Sep 2016, 07:06 pm
Default Blue Devil Head Gasket Sealant
My daughter has a 2004 basic PT with a stick shift and she loves it. She has about 92k miles on it. Did the timing belt package repair which went OK. Now there seems to be a small coolant leak. Her mechanic said she could live with it, monitor it, and start looking for another car. OR, use the Blue Devil Head Gasket Sealant which his shop does not do because of all the complaints about it. Any suggestions????
Old 09 Sep 2016, 07:43 pm
Default Re: Blue Devil Head Gasket Sealant
Worked well for this car...
Old 09 Sep 2016, 08:29 pm
This may be an alternative?
Every *engine I built for my customers they got a bottle of this which was required used for the warranty.
Moroso 35500 Ceramic Engine Seal
*Although I did occasionally built a stock engine form someones grocery getter or succor moms van or tow car/truck, my business was primarily Performance Engines for Race vehicles.
Old 09 Sep 2016, 08:43 pm
Moroso 35500 Ceramic Engine Seal says it works only with cars running water, not antifreeze...has that been your experience?
Old 09 Sep 2016, 09:21 pm
_PTGT03's Avatar
using those off the shelf fix-it products are worth it if it provides a fix, even if it only lasts 6 months. bobistheoilguy website has reviews on a lot of these automotive oil and coolant additives.
Old 09 Sep 2016, 10:46 pm
rsrocket1's Avatar
The Moroso, or it's supplier (Irontite) worked for me in stopping a leaking heater core. Frankly, I would have preferred to learn how to replace a head gasket rather than the heater core on the PT because you have to remove the entire dashboard for that job. I was having a cloud of coolant vapor coming out of thr vents and coolant building up on the floor at on the driver's side. After using a pint of the sealant, the leak has stopped completely and the coolant temperature has been rock solid at 195 whether the outside temp has been 58 or 110F.
You do have to empty the coolant, flush it with water and run it with the sealant for an hour. Then you have to drain it and let it sit empty for a day before filling it back up with coolant.
I've been very impressed with this product so far.
Thanks NitroPT
Old 10 Sep 2016, 08:58 am
You may only have a hose or other gasket leaking if this happened right after the belt job. At any rate the two products recommended here are good. There is another you can do yourself. I have used it manny time without any problems. This company makes to many different ones in my opinion. But if you get this one it does work. No draining necessary. You just follow the directions. Bar's Leak block seal permanent head gasket fix. 25 to 28 bucks. Don't go with the cheaper ones. As I have no idea of how well they work. I only use about a half a bottle on small leaks. And problem is gone. You may not even have a head gasket problem like I said earlier. You can do this without paying a shop. For that matter your daughter can actually do this. It's that easy. Do not add this in the overflow. It needs to be put into the engine while cold and ran for 30 minutes.
Old 10 Sep 2016, 11:28 am
She does have a really small leak according to her mechanic with no overheating or clouds of smoke or big pools of coolant on the floor so the Bar's product sounds like a winner.
Old 11 Sep 2016, 12:19 pm
My daughter talked to her mechanic again and he said the leak is from the engine block itself not the head gasket
Old 11 Sep 2016, 12:22 pm
Yes...so I suggest to try the MOROSO!!!
Head Gasket Sealant Lakotamani Tech & Performance Forum 1 04 Nov 2013 05:45 pm
PT Getting New Cylinder Head, Head Gasket, Water Pump. What Could I Mod? 06turbolite Tech & Performance Forum 8 14 May 2013 09:16 am
03 pt turbo oil in water new head gasket fresh head strokedoutss General Turbo Discussions 7 17 Apr 2013 04:22 pm
Whats the Head flat spec. for head gasket. Busted_PT Tech & Performance Forum 7 26 Apr 2012 08:16 am
WARPED HEAD / SCORED CAMSHAFT / BLOWN HEAD GASKET amadeo Tech & Performance Forum 5 12 Apr 2011 01:03 am
