Fan relay low speed
Like Tree6Likes
Old 10 Sep 2016, 04:11 pm
Govert's Avatar
Default Fan relay low speed
Hi,
I am new to this forum and recently the owner of a 2000 PT Cruiser 2.0 I have some problems with the car and need some help.
The first problem I found was that the cooling fan is not working.I did some research and read some on this forum and noticed that the low speed relay is missing in my Cruiser (I also get engine code P1490).
My question is, which relay should I buy exactly? Has it an OEM part number, or maybe someone has a photo of this relay?
Thanks for helping!
Greetings from Sweden,
Govert
Old 10 Sep 2016, 04:23 pm
rckstein's Avatar
Default Re: Fan relay low speed
Welcome to the forum
Govert likes this.
Old 10 Sep 2016, 04:48 pm
Because Trump
Old 10 Sep 2016, 05:05 pm
Govert's Avatar
ok but it goes into a 5 pin connector is that right?
Old 10 Sep 2016, 05:18 pm
The part number is for a 2001 PT Cruiser 2.4 engine low speed radiator fan relay so I would suggest you call to verify this number. I only have part catalogs that goes back to 2001.
04638094
I am also having trouble with the part number being recognized in the Chrysler Parts Catalog. I would suggest to find out if they changed the part number to 04727370AA.
04727370AA - 5 Terminal Square Relay, POWER DISTRIBUTION CENTER
Search Parts like 04638094
Verify that this is the correct part for your PT Cruiser.
Old 10 Sep 2016, 06:52 pm
Govert's Avatar
Little bit confusing different numbers 4- or 5- pin I just want to be sure which relay to buy, information is here in Sweden very low.
I found this in an online store, but it is also a 4 pin, so I'm not sure.
VEMO Relä, kylfläktslutning (V15-71-0007)
Old 10 Sep 2016, 07:08 pm
It seems to me you have a 5 pin connector in the Power Distribution Center for the low speed radiator fan if you asked this question. Can you confirm that there is 5 slots or is it 4 slots? Post a picture of it if you can.
Old 10 Sep 2016, 07:21 pm
Govert's Avatar
Yes that's right its a 5 slots connector.
Old 10 Sep 2016, 07:37 pm
When I input the 2001 Pt Cruiser 2.4 low speed radiator fan #04638094 it came up with a new part number so its best to confirm with the dealer that the new part number will work with your PT Cruiser.
When you click on the link below it has the #04638094 and it triggered a similar part number but do confirm it with the dealer.
Old 10 Sep 2016, 11:22 pm
Because Trump).
Locating Radiator Fan relays High Speed and Low Speed CashReject Tech & Performance Forum 14 06 May 2017 12:12 am
low speed fan relay trkrdi PT Cruiser Videos 2 15 Mar 2015 11:54 am
high speed fan relay wwwthis General Turbo Discussions 7 19 Sep 2014 08:23 pm
Low Speed Radiator Fan Relay gminfla Tech & Performance Forum 6 27 Jun 2013 10:23 pm
Is the 4 Speed A/S realy a six speed? Ian-PT-GT General Turbo Discussions 11 16 Apr 2004 10:19 pm
