intake leak
Old 11 Sep 2016, 08:51 pm
Default intake leak
Hi Everyone
I had a issue where the upper intake gaskets were failing (you can hear the air sucking in by the radiator cap). I installed new ones. The car runs much better, no more rough idle and stalls. However I still feel and hear air getting sucked in on that back left corner near the radiator cap. My questions is, do I need to use some sort of RTV sealant? These gaskets are rectangular and there are 4 of them. I don't see a crack in the plastic anywhere.. should I consider replacing the upper intake?
Thanks
Anthony
2005 PT cruiser Base Model
Old 11 Sep 2016, 08:58 pm
rckstein's Avatar
Default Re: intake leak
Welcome to the forum
Old 11 Sep 2016, 09:17 pm
Welcome to the forum.
Are you using the correct torque and tightening down the bolts of the upper intake in the correct sequence?
105 Inch pounds 5-3-1-2-4
Old 12 Sep 2016, 12:44 am
Originally Posted by tnyl83 View Post
Hi Everyone
Thanks
Anthony
Has the engine been overheated?
Old 12 Sep 2016, 04:36 am
_PTGT03's Avatar
pressurize your intake system and spray it down with soapy water at the mating surfaces to check for the source of the leaks
Old 12 Sep 2016, 11:16 am
I didn't use the torque specs, just tightened till snug. I will do that and post update after.
Thanks
Athony
Old 12 Sep 2016, 11:25 am
rckstein's Avatar
Thanks
Athony
Oh my, I'm afraid you might get beat up a little on here for not following the torque specs.
Old 13 Sep 2016, 08:09 am
rsrocket1's Avatar
Get yourself a set of torque wrenches. Even the cheap Harbor Freight ones at ~$20 are better than "feel". For around $60, you can have a 1/4", 3/8" and 1/2" set of torque wrenches that would cover everything on your car. You'd be surprised at how little 8.75 ft-lbs of torque is.
The previous owner of my PT stripped out the brass insert on the front of my intake manifold. Fortunately it was not causing a leak but it wasn't holding anything down either. A JB Weld job fixed it but there are probably better adhesives suited for the plastic.
Electric SUPERCHARGER TURBOCHARGER KIT 900 Watt Intake Turbo Cold Air Intake nox440 Tech & Performance Forum 18 06 Jan 2015 09:15 am
intake leak im_so_not_blonde Tech & Performance Forum 20 17 Sep 2014 12:27 pm
wtb 05-up upper intake manifold, throttle body, intake hose to turbo,aircleanor lid 1autodr Classifieds: Want To Buy 1 24 Feb 2011 05:15 pm
Plastic Intake Manifold cracked-boost leak! littleblueGT General Turbo Discussions 1 31 May 2007 03:25 pm
Upper/lower intake manifold gasket leak? im4gzs Tech & Performance Forum 14 03 Jan 2004 01:52 am
