2001 PT cruiser base
  • 1 Post By ptcruisersteve
Old 12 Sep 2016, 07:38 pm
Default 2001 PT cruiser base
I am new here and hope I am staying within the boundaries of the forum. my car recently displayed a 0401,0403 & 1684, after reading some of the forums input I took the advise and purchased a EGR & solenoid and install it and cleared the codes, after a day of riding no codes!! I really thought that I had done pretty good. the next day I drove the car to work to get it inspected and still no engine light! I was going to my regular place where I get my car inspected but just arriving the light came on, I noticed before the light my vehicle hesitated and ran a little rough, I read the code and now a P0172 has come up (which was never there before) and also the 1684 came back. I am at a loss and really need some advise as to maybe why this code popped up
Thank you.
Old 12 Sep 2016, 07:48 pm
rckstein's Avatar
Default Re: 2001 PT cruiser base
Welcome to the forum
Old 12 Sep 2016, 08:06 pm
Please post what each code reads as. I know a 401 and 403 are misfires in cylinder 1 and 3, but the rest could use more information so the rest of us don't have to go looking through a manual.
03' Dream Cruiser Manual: 130k Stage 1, BOV, Koni Shocks, Eibach Springs/Sway Bars, TSW 18x8 Rims, Composite Manifold, 3inch Catless
Downpipe w/Cutout, Magnaflow Catback, Quaife LSD
04' GT Manual Purple PT Mileage: 95k (Died Spring 2018)
05' N/A Automatic Red PT Mileage:121k (Died summer 2017)
Old 12 Sep 2016, 08:20 pm
UnitD77 Please do not make statements that are not accurate. We don't tolerate inaccurate information on this forum. Thank you!
P0401 - EGR System Fault
Possible Causes:
EGR valve control circuit open, grounded or shorted to power
EGR exhaust transfer tubes blocked in the exhaust manifold
ASD relay power circuit open to the
EGR solenoid EGR valve is damaged or has failed
PCM has failed
P0403 - EGR Solenoid Circuit Conditions
Possible Causes:
EGR solenoid ground circuit is open
EGR solenoid control circuit is open or shorted to ground or to voltage
EGR solenoid power circuit is open
EGR solenoid is damaged or has failed
PCM has failed
Old 12 Sep 2016, 08:32 pm
Thank you.
P0172- Fuel System Rich (Bank 1) Conditions:
Possible Causes:
Base engine fault
EVAP vapor recovery system failure
Fuel control Sensor is out of calibration
Fuel delivery component fault
O2 element is contaminated, deteriorated or it has failed
O2 heater is damaged or has failed
Since your previous two codes are effecting the 02 sensors I would check to see if the 02 sensors is working properly.
How many miles on the engine?
Is the engine oil level too high?
Is the canister full of fuel? You are running rich!
How is your gas mileage?
VOS likes this.
08 BASE PT cruiser 2.4 NO START!? HELP!!!! simmonstech Tech & Performance Forum 9 09 Apr 2013 07:49 am
Door Chime Problem 2001 Base Model-HELP!! Bigw123 General PT Cruiser Discussions 8 02 Apr 2012 03:30 pm
PT CRUISER vs Challenger(base) mjb457 General PT Cruiser Discussions 4 26 Mar 2011 08:46 pm
Parting Out 2005 PT Cruiser base base model taftboys Classifieds: For Sale/Trade 9 07 Oct 2010 07:13 pm
No start - 2001 base model bobdole369 Tech & Performance Forum 8 05 Mar 2009 08:58 pm
