What is this for ?
Old 18 Sep 2016, 12:31 pm
Default What is this for ?
On my 2004 Gt, i would like to know what is this for and if I can take it off permanently ?
PT CRUISER 2L 2000 STARTECH
PT CRUISER 2,4L GT 2004
CHRYSLER VOYAGER 3.3 1993
CHRYSLER VOYAGER 3.8 AWD 1997
CHRYSLER VOYAGER 2.5 CRD 2003
Old 18 Sep 2016, 01:01 pm
Default Re: What is this for ?
Because Trump
Old 18 Sep 2016, 01:07 pm
it s fix on the AC bottle fitting and I would like to take off the bottle .
Old 18 Sep 2016, 01:08 pm
What the purge solenoid do ?
Old 19 Sep 2016, 08:53 am
EVAP system is for fuel vapor recovery and reuse. Do not remove. You could explode your gas tank by over pressurization. You would not gain anything by removing it.
03' Dream Cruiser Manual: 130k Stage 1, BOV, Koni Shocks, Eibach Springs/Sway Bars, TSW 18x8 Rims, Composite Manifold, 3inch Catless
Downpipe w/Cutout, Magnaflow Catback, Quaife LSD
04' GT Manual Purple PT Mileage: 95k (Died Spring 2018)
05' N/A Automatic Red PT Mileage:121k (Died summer 2017)
Old 19 Sep 2016, 09:21 am
Because Trump
Old 19 Sep 2016, 09:22 am
Thank you
I don't want gain anything, I just want to take the AC bottle and it is fix on the support .
Old 19 Sep 2016, 09:23 am
Originally Posted by sanatanadharma View Post
"The evaporation control system prevents the emission of fuel tank vapors into the atmosphere. When fuel evaporates in the fuel tank, the vapors pass through vent hoses or tubes to an activated carbon filled evaporative canister. The canister temporarily holds the vapors. The Powertrain Control Module (PCM) allows intake manifold vacuum to draw vapors into the combustion chambers during certain operating conditions.
All engines use a proportional purge solenoid system. The PCM controls vapor flow by operating the purge solenoid."
"OPERATION
All vehicles use a proportional purge solenoid. The solenoid regulates the
rate of vapor flow from the EVAP canister to the throttle body. The PCM
operates the solenoid. During the cold start warm-up period and the hot start time delay, the PCM does not energize the solenoid.
When de-energized, no vapors are purged.
The proportional purge solenoid operates at a frequency of 200 hz and is controlled by an engine controller circuit that senses the current being applied to the proportional purge solenoid and then adjusts that current to achieve the desired purge flow. The proportional purge solenoid controls the purge rate of fuel vapors from the vapor canister and fuel tank to the engine intake manifold."
"If the engine is shut-off while the On-Board diagnostics test is running, low level tank pressure can be trapped in the fuel tank and fuel can not be added
to the tank until the pressure is relieved.
This is due to the leak detection pump closing the vapor outlet from the top of the tank and the one-way check valve not allowing the tank to vent through the fill tube to atmosphere. Therefore, when fuel is added, it will back-up in the fill tube and shut off the dispensing nozzle."
Thank you for this
Old 19 Sep 2016, 09:51 am
_PTGT03's Avatar
what is your intention to remove components permanently ? weight reduction ? performance ?
Old 19 Sep 2016, 10:43 am
Like I said,I want to take off the AC bottle on this EVAP Control is fix on it .
