Head job done! Somethings not right!
Like Tree4Likes
Old 18 Sep 2016, 01:26 pm
Default Head job done! Somethings not right!
I ended up pulling my head. I had it re-done. Replaced water pump. timing belt.. and all the rest that goes with that horrible job.. when i started her up i got a p0016 error code for a few seconds. Then it went away. Engine light stayed on and code came back p0301 misfire cylinder one.
Heres what is going on. When i drive the car every now and then especially when i first get going in the morning she will rev up to 5000 no problem and feels good. but after 15 minutes of driving she will sputter at 3500 and it almost feels like the rev limiter kicked in and i cant get over 3500. but then every now and then she will rev up too 5500/6000 floored no problem, and them back to running off. She starts and idles purrfectly @ about 800 and feels responsive. Looking for ideas!!
Old 18 Sep 2016, 01:43 pm
Default Re: Head job done! Somethings not right!
It's interesting that it will rev up to 5000+ as the rev limiter on all models should cut in way before that. The limiter is set to about 3500-4000 and shouldn't let the engine rev past that when your in Part or Neutral.
Old 18 Sep 2016, 01:53 pm
Handy_Cruiser's Avatar
Are you sure you are not getting a cam sensor code? This is similar to way my GT acted with the cam sensor died.
Old 18 Sep 2016, 02:00 pm
I guess my thought process is.... If it were the timing belt off by a tooth... should it be a consistent fail?
Sometimes she runs right 30% of the time and 70% cant get passed 3500.
I replaced the camshaft position sensor to no avail.
If i upload a video will that help? I will go make one.....
Old 18 Sep 2016, 02:09 pm
Old 18 Sep 2016, 02:51 pm
https://youtu.be/YUNzH0K2Qbw
here is the vid. don't know if it helps but i have never had a car that the rev limiter kicks in half way before you even get to the red limit of the factory tach. And i did not have this problem before. and i don't think that rev limiters kick in way before the factory tach says it should.... i may be wrong but i just ain't seen it bfore. hope someone can help!
Old 18 Sep 2016, 03:18 pm
crusofthebisquit's Avatar
Are you sure your not hitting the 2500 limp home limiter......if so we may be in the same boat.
Trying to get balancer off now.
OK I watched your vid now and am edititing......still seems like limp home to me though.
ain't this boogie a mess
Old 18 Sep 2016, 03:22 pm
It's a good idea to have your city on profile......you could be around the corner from another member who hates football.
Old 18 Sep 2016, 03:29 pm
Agreed feels like limp home... My worry is.. Is this a symptom of being off a tooth on the timing? Or is my timing fine and i have other issues?
Old 18 Sep 2016, 03:46 pm
WrenchnIswhatIdo's Avatar
if your were off a tooth
you would have other symptoms.....
Hard to start
Very sluggish... all the time
Pinging on acceleration
Do a compression check
Let see those plugs
Revist your grounds and electrical conectors
Tags
cam crank sensor, error codes
rebuilt pcm and 6 new codes? obviously somethings amiss hillbilly678 General PT Cruiser Discussions 3 19 Jul 2012 08:04 pm
somethings wrong with my car Sharkstooth General PT Cruiser Discussions 2 23 Jan 2012 07:55 pm
WARPED HEAD / SCORED CAMSHAFT / BLOWN HEAD GASKET amadeo Tech & Performance Forum 5 12 Apr 2011 01:03 am
Cruisermania II-somethings happening THISLPT General PT Cruiser Discussions 3 25 Aug 2004 04:19 pm
Somethings really wrong with my car ! mkqswt Canada PT Forum 4 05 Feb 2004 12:37 pm
