ECT sensor
  • 1 Post By Handy_Cruiser
Old 20 Sep 2016, 02:28 pm
Default ECT sensor
I am trying to change the ECT sensor in my 06 pt cruiser. The car is over heating in stop and go traffic, but runs fine as long as there is wind blowing into the radiator. The fan is not running when the car gets hot. The fan does run when the AC is on, I have rep[laced the fan, and checked the relays. Anyway, I know where it is, and have researched how to get to it, but all I can find is things like "its hard to get to, but you can do it". My question is, do I need to Remove the whole radiator fill assembly, is there a special tool I can use to get to it? No matter how hard I try, I can not get a wrench in there as it is butted right up against the radiator fill neck. Any advice would be appreciated.
Old 04 Oct 2016, 06:04 pm
Default Re: ECT sensor
I just ran out and looked at mine. The service manual doesn't really say how to get to it. If I were you, I'd remove the 4 bolts holding the power steering fluid reservoir so that you can move the hose out of the way a little bit better. I'm assuming that you're talking about the coolant temperature sensor. You might need some extensions and swivels.
2008 PT Cruiser Touring 135,000 miles
Old 04 Oct 2016, 06:25 pm
Handy_Cruiser's Avatar
Take the top radiator brace off and things became simpler.
CrankShaft Sensor/CamShaft Sensor Questions PTMomma Tech & Performance Forum 8 12 Aug 2014 01:43 pm
Crank sensor/ Cam sensor BigBear General PT Cruiser Discussions 0 23 Jul 2013 11:00 pm
Crankcase sensor /Camshaft sensor PigFarmer Tech & Performance Forum 21 20 Mar 2012 07:01 pm
crankshaft position sensor veses knock sensor BeagleDad Tech & Performance Forum 6 13 Feb 2012 06:10 pm
Cam Sensor code changed sensor still dead RottenKid Tech & Performance Forum 8 18 Nov 2008 08:17 am
