Broken odometer button - is it just a switch or a switch/knob?
Like Tree10Likes
  • 1 Post By Prostheta
  • 1 Post By Gkon
  • 3 Post By Handy_Cruiser
  • 1 Post By Gkon
  • 1 Post By Handy_Cruiser
  • 2 Post By Prostheta
  • 1 Post By Gkon
Old 21 Sep 2016, 07:49 am
Prostheta's Avatar
Default Broken odometer button - is it just a switch or a switch/knob?
Mine came like this from having picked her up. If it's a switch, that's no big deal. If not....depends if it's simply the shaft or the component itself that's broken....
How do the hell do you do this, anyway?
Gkon likes this.
2001 2.0l PT Cruiser Touring Edition
Mods: New gear knob, blue LED re-lighting, token chrome bits.
215'000km (55.9% distance to the moon, 71.7% of a second at light speed, Usain Bolt running for 200 days)
"People demand freedom of speech as a compensation for the freedom of thought which they seldom use" - Søren Kierkegaard
"What can be asserted without evidence can be dismissed without evidence" - Christopher Hitchens
Old 21 Sep 2016, 08:16 am
Gkon's Avatar
Default Re: Broken odometer button - is it just a switch or a switch/knob?
I don't know for sure, but I'm guessing the plastic shaft depresses a push switch on a circuit panel.
Regardless, is there any of the shaft still intact inside of the hole? If so, depress it with something round and skinny that fits in the hole.
One quick press switches to a setable odometer, a second press shows the overall miles on the car. In the setable mode, if you then hold the shaft down for 2-3 seconds, it will reset the ODO to 0.
Handy_Cruiser likes this.
2002 PT Cruiser Limited, 2.4L, Automatic Transmission, Metallic Silver Paint
Handy_Cruiser's Avatar
If made like the North American models, the button is just a plastic rod that pushes a small flat switch on the cluster circuit board.
Here's some photos of a 2003 GT instrument cluster that I took apart. It will be very similar to your 2001 NA cluster. You can see the rod in the first photo and the flat switch on the circuit board in the second. If your switch just appears physically broken, chances are that you just need to replace the rod in yours. But you will have to take the cluster all apart to do this.
A better choice might be to just replace the entire cluster with one from a salvage PT. If like the North American models, a 2001 thru 2005 cluster from a non-turbo PT with the same transmission (auto/manual) should likely work. However, the odometer reading is stored in the cluster. So it will read the mileage that was in the salvage car.
Old 21 Sep 2016, 01:50 pm
Gkon's Avatar
Hey, so my guess was correct! Hi-five for me
Old 21 Sep 2016, 02:01 pm
Gkon likes this.
Old 21 Sep 2016, 02:03 pm
Prostheta's Avatar
Gotcha, perfect info...over and above guys!
It's just a standard microswitch, so even if it is damaged I can easily resolder in a new one within a minute or two. I'll see how the thing was retained first and see whether I need to turn an acrylic rod on the lathe or weld on some sort of tab to stop it falling out.
I've got an indicator bulb to replace in there too, so whilst I'm at it I might replace the cheesy transparent left/right arrows with some chrome jewel lenses and LEDs. After all, "what not?".
Handy_Cruiser and Gkon like this.
Old 21 Sep 2016, 02:15 pm
Gkon's Avatar
Glad to help!
I suggest you replace all the dash bulbs while you're at it. LED's are pretty snazzy, too.
BTW, in case you don't know, when you remove the gauges, don't turn them upside down (for any length of time). You'll mess them up.
There's a good write up somewhere here on the forum about replacing the bulbs. I'll see if I can find it for you.
Old 21 Sep 2016, 02:16 pm
Gkon's Avatar
Thank you!
Old 21 Sep 2016, 02:21 pm
Gkon's Avatar
Just in case you need it:
PT Dash Lamp Replacement
FS: 2008 OEM 'Combo Switch' (turn signal/headlight switch) Maxxam Classifieds: For Sale/Trade 3 08 Aug 2017 06:23 am
Multifunction Switch - Headlights not working - can I use switch with Fogs? bwiencek General PT Cruiser Discussions 1 13 Oct 2014 01:51 pm
Lighted 5 Button Master Window Switch soonercruiser Classifieds: For Sale/Trade 2 12 Feb 2014 09:41 pm
Very Odd Defrost Switch/Button Problem - Please Help!!! Surf_Blu_Baby General PT Cruiser Discussions 8 22 Sep 2011 03:22 pm
WTB 4 button window switch Franksredpt Classifieds: For Sale/Trade 2 04 Dec 2008 09:24 pm
