PCM/SKIM issues
Old 27 Sep 2016, 11:38 am
Default PCM/SKIM issues
New here, so I'm hoping this is the right place for this.
I have a 2007, Non-Turbo, Touring Edition with about 177k.
I'm having this issue where I put the key in and the car starts, runs for about a second or two, and dies. The red security light starts flashing when it dies. It used to do it every once in a while (every 20 starts or so), but now it's doing it every time. Shows a code P0513, which is invalid SKIM key.
I've done a little reading both here and other forums, and it sounds like a problem with the PCM. I've found replacement ones on eBay for $120 or so, which say they will program it to my VIN.
But I have heard that there is a separate programming that needs to be done for the SKIM key, and some places say to simply have the key chip reprogrammed. I don't wanna buy the PCM if I can just have the key fixed, or have a new key made.
Does anyone have any suggestions as to what I should do first? I want to get this fixed as cheaply as possible.
Old 27 Sep 2016, 12:14 pm
VsandFords's Avatar
Default Re: PCM/SKIM issues
I don't have an answer for your problem. I just wanted to say, welcome to the forum. There is someone here that will be able to help with this.
Old 27 Sep 2016, 12:32 pm
Welcome to the forum.
Old 27 Sep 2016, 02:15 pm
Handy_Cruiser's Avatar
Welcome to the forum from the great sovereign state of Arkansas!
Your issue may be the PCM, SKIM, sentry key or the wiring harness in between.
First, if you have a second sentry key, try it. There's chance the SKIM will detect the second key where it no longer detects the first one.
If no joy, you may find it difficult to go further with this your self. Without a DRBIII scan tool or other similar system, it becomes almost impossible to diagnose this issue at home except for changing out parts and hoping for the best. And the only way I would attempt this is if a I had another PCM, SKIM and sentry key that were already mated together. Just purchasing a another PCM (flashed to your VIN) is going to be a gamble since the problem may not be the PCM at all.
In this instance, I believe the cheaper and likely better solution may be to take your PT to a shop with the proper diagnostic tools. Luckily, some shops have this equipment now so you do not necessarily have to go to the dealership like you would have just a few years before.
Old 27 Sep 2016, 02:41 pm
P0513 - Invalid SKIM Key.
Possible Causes:
1. Incorrect VIN in PCM
2. Invalid SKIM key not present ( Sentry Key Immobilizer Module (SKIM)
3. No communication with SKIM
4. No VIN programmed in the PCM
5. PCM
Old 27 Sep 2016, 04:18 pm
There is a TSB on this problem. Cannot find it right now..
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 27 Sep 2016, 04:33 pm
There is 26 confirmed fixes on the information below.
1. Vehicle was towed in for a no start condition. The vehicle will not crank or start....
2006 Chrysler PT Cruiser 2.4L, Vin B
Test Details... Confirmed Fix Details...
Tests/Procedures: 1. Check the codes in the Powertrain Control Module (PCM). 2. If there is a P0513, check the codes in the Sentry Key Remote Entry Module (Skreem), Sentry Key Immobilizer Module (SKIM) or Wireless ...
26 Confirmed fixes
Security Key Remote Electronic Entry Module (SKREEM)
Sentry Key Immobilizer System (SKIM) Key
9 - Sentry Key Immobilizer (SKIM) Key
3 - Ignition Lock Cylinder Housing
2 - Fuse #33
2 - Security Key Remote Electronic Entry Module (SKREEM)
1 - Ignition Lock Cylinder Housing, Ignition Switch
1 - Keyless Entry
1 - Security Key Remote Electronic Entry Module (SKREEM), Sentry Key Immobilizer (SKIM) Key
1 - Ignition Key(s), Security Key Remote Electronic Entry Module (SKREEM)
1 - Powertrain Control Module (PCM), Security Key Remote Electronic Entry Module (SKREEM)
1 - Ignition Switch
1 - Battery Disconnect/Reconnect
1 - Ignition Lock Cylinder, Ignition Switch
Old 28 Sep 2016, 03:12 pm
GUYS! A BREAKTHROUGH!
The problem isn't 100% fixed but I'm going to put this here in case it helps anyone.
I had noticed that if I turned the key to the on position, but didn't start the car, I could wait to see if the security light came on. No light = no problem starting, but if the light flashed, I knew not to even bother starting the engine because it wasn't going to work. So...
I was messing around and noticed if I pushed the key into the ignition really hard while I was turning it, the whole ignition cylinder would push in a couple centimeters. No security light. Doing this allowed me to start the car no problem!
Obviously the problem isn't really fixed, but I least I have a workaround to be able to use my car while I try to fix it. Still shows code P0513.
I can get a new ignition for relatively cheap. Does anyone have thoughts as to whether or not that's where the issue is? I plan on taking it to a mechanic with a drbiii this weekend, but any extra input is totally welcome.
Old 28 Sep 2016, 07:12 pm
Based on what you've said, it sounds like the plastic shaft on the lock cylinder is not fully going into the ignition switch. So the ignition switch is not turning far enough during start up. It could also be the ignition switch itself. And by the pushing in, it allow the ignition switch to turn just a little further.
If me, I'd remove the steering column cover and see if I can tell what's going on when you press in on the lock cylinder. It's a pretty simple setup once you see it.
Old 28 Sep 2016, 11:57 pm
If the lock cylinder came loose enough causing the rod going to the ignition actuator to fall somewhat short there might be some damage to the ignition actuator. Check the ignition actuator.
PCM and skim for sale DODGETHIS Classifieds: For Sale/Trade 9 08 Feb 2015 01:47 pm
Help needed: 2007 PT Won't Start: Alarm / RKE Module - SKIM Key Issues bluebossa Tech & Performance Forum 6 05 Oct 2013 11:55 am
Skim key stu88 Tech & Performance Forum 15 17 Aug 2013 04:01 am
SKIM Woes wirelessdog Sound and Security Forum 4 14 Jul 2012 08:54 pm
SKIM 99PlyNeon General PT Cruiser Discussions 0 30 Jul 2011 08:01 pm
