CONFUSED Overheating kind of
  • 1 Post By ptcruisersteve
Old 02 Oct 2016, 11:51 am
Default CONFUSED Overheating kind of
So I am having odd to me PT issues. I have a daily drive that has enough stop and go to make me crazy. I am a gauge freak which I feel is a good thing. My car runs dead center on temp and if sitting will go to 3/4 and back to half. Usually this leads me to put fluid in the overflow which is again empty. So I recently drained my radiator and changed fluid all went well refilled it ran heater set overflow to correct level. Well driving to work temp at half stopped I notive the mist of antifreeze steam. Get to work looks like an issue with hose that runs to overflow cut ithose clamp all good. Few days later same thing check radiator at end of work shift it is full overflow looks empty? Totally lost where/why?
Old 02 Oct 2016, 12:08 pm
Default Re: CONFUSED Overheating kind of
I would suggest that you are getting air into the engine cooling system. Suggest a engine coolant pressure test to make sure your system is pressurized to keep the engine coolant temperature from rising. Check your radiator cap to make sure its working properly.
If the engine coolant pressure test checks out good I would suggest with the engine cold, take off the radiator cap, start the engine and see if you can see bubbles coming up. Take some of the coolant out if it is right to the top. Do not leave the engine running very long as the coolant will rise and overflow without the radiator cap being on it.
Old 02 Oct 2016, 01:57 pm
Check overflow tank and hose for cracks, check both sides of the radiator seams where the aluminum is crimpted to the plastic tanks. The the mounting base of the radiator pressure cap fill tube. Look for a build up of dry or damp chemicals.
Check to make sure your radiator cooling fan is cycling. Mine starts to cycle before temp gauge reaches NOT. (Normal Operating Temp)
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 02 Oct 2016, 06:28 pm
Don't over look the basics ... take a look at your radiator cap if the rubber gasket is cracked ... it won't hold pressure.
Old 02 Oct 2016, 06:52 pm
I just completed a time belt, water pump replacement..... and I found an Aluminum AC line coming off the pump that was rubbing a hole in the lower radiator hose. The aluminum tubing also had wear on it from the rubbing.
73 Charger SE
01 Sebring flip
Old 03 Oct 2016, 06:57 am
Mine was doing the same thing and it turned out to be the radiator cap. The spring was worn out and not holding pressure. A quick and simple fix.
Old 03 Oct 2016, 09:11 pm
Thanks for the info I will purchase a new cap.
Old 19 Oct 2016, 07:32 pm
So new cap and still a issue. Doesn"t overheat bounces between middle and 3/4 temp? Used to hear fans when Iturned off car haven"t heard them in awhile. Is there a test to check them?
Old 19 Oct 2016, 10:46 pm
Anytime its over the middle of the engine temperature gauge its overheating. I would suggest fixing it immediately.
Manually check your radiator fans by apply 12 volts to both high and low speeds after you disconnect the plug.
Imakenocents likes this.
QUITE CONFUSED... SNARFUS Tech & Performance Forum 1 12 Jun 2015 01:02 pm
OMG So Confused about 06 Key Fob flafishergal General PT Cruiser Discussions 4 21 Jan 2011 06:13 pm
overheating and a radiator flush...kind of notarobot General PT Cruiser Discussions 4 28 Mar 2010 07:57 pm
New and confused mapowellsr General PT Cruiser Discussions 1 24 Mar 2010 07:20 pm
Confused 07PTSilver General PT Cruiser Discussions 8 22 Dec 2008 12:42 am
