Bad mileage, rough idle
Like Tree2Likes
Old 02 Oct 2016, 04:51 pm
Default Bad mileage, rough idle
Just changed the plugs which were nice and tan after 50 k miles. It did not solve the problem. 150k on vehicle, 50 k on wires. I have a rough idle and bad mileage. Was thinking of changing the wires again and the 02 sensor since its never been changed. It is a 2008. I do not have an egr or a vaccum line on the map sensor. seems to be missing a little when cold.
Old 02 Oct 2016, 06:00 pm
Default Re: Bad mileage, rough idle
Your engine light on? If so what are the engine trouble codes?
With 150k we need a little history on whats been done to the engine.
Old 02 Oct 2016, 07:20 pm
No engine codes. 3 dings when I start the car. head replaced at 100,000 miles along with timing belt and cam sensor. Head had a burnt exhaust valve. At about 145K the car started pinging, less after changing the spark plugs.
Old 02 Oct 2016, 08:06 pm
I would suggest connecting a hand vacuum gauge to the intake manifold either tee into the PCV or the brake hose. Than start your engine and report what the gauge is doing.
If you do not have one than now is the time to invest in one! They are at most all better auto parts chain stores for a very low price.
VOS likes this.
Old 04 Oct 2016, 05:52 pm
Harbor Freight has pretty good deals on vacuum pumps. They also come in handy for bleeding brakes.
2008 PT Cruiser Touring 135,000 miles
Old 04 Oct 2016, 06:00 pm
Did you ever figure out what caused the burnt exhaust valve? I bet it is the same problem.
And don't tell me the exhaust valve just burned over time. something like a burnt valve don't just happen unless something goes wrong.
03' Dream Cruiser Manual: 130k Stage 1, BOV, Koni Shocks, Eibach Springs/Sway Bars, TSW 18x8 Rims, Composite Manifold, 3inch Catless
Downpipe w/Cutout, Magnaflow Catback, Quaife LSD
04' GT Manual Purple PT Mileage: 95k (Died Spring 2018)
05' N/A Automatic Red PT Mileage:121k (Died summer 2017)
Old 05 Oct 2016, 08:38 pm
I do not know what caused the burnt valve. Around the same time I ran it 2 quarts low on oil. Shortly after that I got a misfire on cylinder 3 code. I thought ignition and changed the plugs and wires and coil pack. Still had the misfire code. I did the old dollar bill on the exhaust trick. Got a suck in so did a compression check, #3 was low and that's the story, burnt valve. That was 55 K ago. Someone told me it could be a lean injector, air leak on the intake. Injectors either work or they don't and all the Gaskets are new. The car actually ran good with the burnt valve, idled smooth, accelerated ok. Just threw a code. Well I didn't notice much difference put it that way. I have noticed a slight fluctuation in the idle. I have never changed the 02 sensor so was thinking maybe its part of the cause. I am going to clean the MAP sensor this weekend, check for a bad vacuum line, etc. Lots of radio noise, maybe its wires? I dunno
Old 05 Oct 2016, 09:40 pm
Fk5 Fk5 is offline
Didn't a bunch of people just post that you can't clean the MAP? I thought that was the consensus in a recent thread. You can clean the IAC.
2003 GT 5 speed
162,000 miles
Old 06 Oct 2016, 05:01 am
Oh. ok. Then I will try the IAC. I may have to solicit the help of my friends mechanic. I guess he has a smoke machine to check the vacuum lines.
Old 06 Oct 2016, 12:26 pm
Actually both on these. Carbon is a big thing on these. This get cought between the valves and seat. Over time this beats up the valve sealing area and begins to leak. Until the point it leaks enough to allow hot gases following out to heat up the valve's edges to the point of melting. The exahast valves should be checked anytime you have to remove the head on one of these.
JoeX likes this.
Stalls at idle. Sometimes. And rough idle scatgo1 Tech & Performance Forum 6 27 Nov 2014 11:04 am
Rough Idle-Replacing the IAC Idle Air Controller engineerrock Tech & Performance Forum 9 07 Jun 2014 07:24 pm
'07 PT - Rough Idle, rough acceleration, and shuts off if it idles for too long La_Bruja Tech & Performance Forum 3 09 Aug 2013 07:50 am
2005 2.4 Turbo: Poor gas mileage, rough idle - at the end of my rope! phraxion General Turbo Discussions 10 03 Nov 2012 10:41 pm
Rough Idle, Rough @60, check engine light NEW Dystroy Tech & Performance Forum 8 12 Jan 2009 09:07 pm
