Gauge cluster lights, shifter lights, and rear running lights out
Like Tree4Likes
  • 2 Post By Jspata
Old 05 Oct 2016, 12:26 am
Default Possibly fixed electrical issue
I have noticed before my dash lights would flicker. One day they just went out. My brother said the rear lights were out on the car though.
I have done some diagnostics and still can't figure it out. Went through probably 20 plus threads of people with the same issues except all of them don't have the issue of when I turn the steering wheel, it blows the parking fuse.
2004 pt cruiser gt auto with 135k miles.
Brake lights, headlights, turn signals, high beams, reverse lights and dome light all work. Horn still works. Only fuse blown is the parking lamp fuse(#10). #13 fuse is also good
My brother was helping me and we checked the amperage and it's like 3.8ish. When I turn my steering wheel left to right, it spikes and the dinging and dash lights flash off and then on again.
Multi function switch doesn't show any signs of burning at the connector. All the wires around the steering column look fine to me. No signs of burning or exposed wire.
Not sure if this is related but when I pull on the key, the radio shuts off. If I push it back in and up, the radio comes back on. The radio shutting off doesn't bother me much. I need help of where else to look for this damn short. I don't know electrical systems very well so I'm hoping someone who knows can chime in. Thanks.
Old 05 Oct 2016, 05:16 pm
Default Re: Gauge cluster lights, shifter lights, and rear running lights out
I just said 10 cause that was labeled gauges. I'm gonna check some more stuff out today. Will post back.
Old 15 Oct 2016, 10:07 am
Have not been able to get it to short out. Seems to be fine. If I can every get it figured out, I will post back.
Old 18 Oct 2016, 04:33 am
Possible fix: checked the wires on the front then signals and the driver side wire right before the connector was rubbing the tire. Explains why after I lowered it, the problem started. The plastic wheel well piece is missing allowing the wire to hang. Fixed the wires and shrink wrapped them. Moved the wire out of the way of the tire. Let's hope it's good.
Need to tap into gauge cluster lights GtPt05 Interior Accessories Forum 16 25 Aug 2016 03:48 pm
2001 no dash lights no rear running lights beley83 Tech & Performance Forum 6 01 Apr 2015 08:37 pm
No Brake lights or tail lights/running lights kitzmann56 General PT Cruiser Discussions 8 14 Feb 2015 03:07 pm
Rear Running Lights out.....need help turbotom General PT Cruiser Discussions 13 10 Mar 2012 04:11 pm
Cluster lights, Fuel Gauge, and Speedo No Workie melmsrt4 General PT Cruiser Discussions 7 27 Jun 2011 12:27 am
