Motor Mount Bolt ?
Like Tree3Likes
  • 1 Post By red98gt
  • 1 Post By Handy_Cruiser
  • 1 Post By Chip18sw
Old 05 Oct 2016, 09:08 pm
Default Motor Mount Bolt ?
Need some help. On the top right mount, there are a total of three bolts. I need to know the bolt size of small front two bolts, and are they met or std. I need to replace them as they were so tight, I rounded the heads. Thanks!
Handy_Cruiser likes this.
Old 09 Oct 2016, 08:26 am
Default Re: Motor Mount Bolt ?
When I did my timing belt, I discovered that the center bolt and the engine support bracket was stripped. You're best bet is to get one from a Chrysler dealer or find one in a salvage yard. Most of the bolts on modern cars are metric and Lowe's and Home Depot only have standard sized bolts.
2008 PT Cruiser Touring 135,000 miles
Old 09 Oct 2016, 12:38 pm
Also needs to be grade 8 hardware I think it's marked as 8.8?? But yeah Pick and Pull or the dealer would be a safe bet.
Stripped center bolt and engine support bracket ... that would suck! A monkey work in the middle of a weekend project. Been there ... well yeah actually ... I'm still there.
Old 09 Oct 2016, 01:05 pm
Handy_Cruiser's Avatar
Those two bolts are M10X1.50X60. I have a spare one on my desk right now where I measured it to make sure. Hardness is 10.9 . Uses a 15mm socket.
You can buy a set of extra hard bolts for this here if interested.
https://www.modernperformance.com/pr...-engine-mounts
JoeX likes this.
Old 09 Oct 2016, 03:08 pm
Hardness is a 10.9??? When did that happen??? Is this new are did I just read stuff wrong???
Old 09 Oct 2016, 11:16 pm
Mine on my PT are 10.9. The spare set I have are too. And the description on the Modern Performance website at the link I posted above also says the original bolts are 10.9. I don't know if all of these bolts are 10.9, but all examples I have are.
Old 10 Oct 2016, 12:49 am
Are these the two bolts you are talking about?
Old 10 Oct 2016, 09:31 am
Thanks a minor point but one I was not aware off?? 10.9 when I upgraded the suspension fortunately nothing stripped, broke or got lost. So I had no need to look at them.
mid- motor mount bolt willy13 General Turbo Discussions 15 30 Mar 2016 11:32 pm
Missing upper motor mount bolt Mbreen General PT Cruiser Discussions 12 17 Mar 2015 07:26 am
Broken motor mount bolt madeupofwires General PT Cruiser Discussions 1 24 Jun 2014 03:58 pm
Sheared Off Motor Mount Bolt - 2001 PT SteveG22 Tech & Performance Forum 7 19 Feb 2014 06:04 am
Lower motor mount bolt sheered off invidious Tech & Performance Forum 6 16 Sep 2013 05:08 pm
