Manual transmission problems
Old 11 Oct 2016, 06:39 am
Default Manual transmission problems
Okay everyone I purchased a 2002 PT Cruiser a couple years ago. From time to time I have had trouble putting it in reverse. Eventually after a little muscle and sometimes tranny fluid it would pop in and I could go on my way however this morning I got up to leave for work and it would not come out of first gear. After a little maneuvering I got it into reverse and backed up the driveway and then ironically it would not come out of reverse so is this my transmission going on me? And if so is this a common problem
Old 11 Oct 2016, 06:36 pm
Default Re: Manual transmission problems
Check the simple stuff first. The shifting is performed by two cables between the stick shift and the transmission. There are two bushings at the transmission and two bushings at the stick shift, under the console. These bushings are known to be a wear item, and have to be replaced during the life of the car.
I've replaced bushings on three occasions. Once, it was pretty dramatic. It popped clean out of gear ~10 miles from home. Fiddling with it, I got it back in gear and nursed it home. The other two times, the bushing replacement was just preventative maintenance.
Oops, the above is for a 5-speed manual. On rereading, you mention adding transmission fluid. Is it an automatic?
Old 11 Oct 2016, 08:59 pm
_PTGT03's Avatar
this guy is right on. for just under $15 you can solve this issue. the transmissions in these cars rarely are a source of problems.
replace the bushings
Shifter Stabilizer Bushings - Dodge Neon - 41605
Old 12 Oct 2016, 12:11 pm
After the bushing change, adjust the shifter cables at the shifter. This promotes easier shifting.
'05 GT Convertible Automatic (daughter's, she calls it "Matilda", I don't) and '05 Cool Vanilla Limited Turbo Lite "Vanilla Thrilla" (wish it was a stick shift)
Manual Transmission Problems HELP PLEASE mefank General PT Cruiser Discussions 1 24 Aug 2013 09:24 pm
Manual transmission htway750 General PT Cruiser Discussions 6 13 Aug 2012 09:47 am
Manual Transmission justn0w General PT Cruiser Discussions 4 18 Oct 2011 11:10 pm
Manual transmission 1gr8rubaz Tech & Performance Forum 0 05 Oct 2007 11:22 am
Manual Transmission Parts? where to buy... runtime Tech & Performance Forum 3 26 Apr 2007 07:24 pm
