fuel pressure bleeds down
Old 12 Oct 2016, 09:20 am
Default fuel pressure bleeds down
I have a 2005 base convertible non-turbo. My fuel pressure bleeds down within a few mins. It runs great, but you have to turn the key on for few mins before you try and start it. I have checked and replaced the fuel pump because I found that it my be the check valve in the fuel pump module. I also checked pressure and fuel injectors for bleeding down. Both checked out good. The only thing I can think of is the line that goes from the fire wall to the fuel rail. It has what I think is some sort of damper, but I cant find anything one way or the other. I was wondering if anyone else has come a crossed this.
Clogged fuel filter, low fuel pressure or what? Gilgrin Tech & Performance Forum 8 01 Jun 2016 04:57 am
What's the minimum fuel pressure for car to run? unioncreek Tech & Performance Forum 5 27 Jul 2012 03:40 pm
fuel pressure check OurPTGT Tech & Performance Forum 7 27 Jul 2012 09:25 am
Fuel pressure regulator. Where it be at? Skye Tech & Performance Forum 3 23 Aug 2010 03:59 pm
Fuel pressure gauge PT GT Turbo Performance 1 14 Jun 2003 09:15 pm
